Hello!
I have an old Fatar Studiologic SL-880 that was lying around for quite some time and I am trying to hook it up to my computer with Roland UM-ONE, which seems to work fine. The keyboard turns on, I can select midi zones, and switch “Enter/Edit” mode on and off (Up and Down keys don’t work, however). The pitch bend works and I can control software with it. The big problem is that all keys don’t work - they give no midi output. The only key that works is C in center (underneath 0 on the numbered scale), but it send out a signal as D#. The volume of that key is generated as it should.
I’m confused. If ALL the keys didn’t work, then that would probably mean something that connects them to the mainboard broke. Do you have any ideas what could be the problem?
Thank you.
Thank you.
