U
Unknown Child
This may sound ridiculous as it did to an old friend (who I no longer speak with or I'd probably ask him) but I have a quick question.
I can be quite stubborn and up until now I've been doing the most CPU demanding style of mixing ever... I utilize inserts to a fault. I am decent at my EQing, my compression... using my ear to find the sound I'm looking for. Problem is, I drop my EQ's into inserts rather than sending the track to a bus. Meaning, if I have 2 vocal tracks that may utilize the same compression settings, I'll just duplicate the plug-in from the first vocal onto the second ones insert section. The reason being is because when I place it directly onto the track via insert it sounds like it directly affects the track. Whereas if I try and run it through a bus I find it doesn't affect the track in the same way, and when I turn up the BUS volume to get it to compress more, it seems it turns up the volume of the track to the point of clipping, rather than giving me the same "compressed sound" I get when I place it directly into an insert.
Why is this? What is it I'm doing wrong? Up until know I reserved my BUSSES strictly for delay's and such. Perhaps I'm just stupid, but can anyone quickly explain how to get the same effect by running it thru a bus rather than placing a compressor on an insert sucking away my CPU processing ability? I hope I've explained this right. Thanks.
