Hey all,
I have recently purchased a pair of PMC DB1I monitors and because my mum got them for me, she thought she was getting active monitors. When they arrived (from the other side of australia) i realised they were passive.
My question is would the Art SLA-2 or Samson Servo 600 power amplifier be over kill for these monitors.
PMC DB1I monitors
Crossover Frequency: 2kHz
Dimensions: H 290mm 11.4" W 155mm 6.1" D 234mm 9.2" + Grille
Drive Units: LF PMC Doped 140mm cast Alloy Chassis, HF 27mm SONOLEX Soft dome Ferro-fluid cooled Effective ATL™ Length: 1.5m 5ft
Frequency Response: 50Hz-25kHk
Impedance: 8 Ohms
Input Connectors: 2 pairs 4mm sockets (Bi-Wire or Bi-Amp)
Recommended Amp Power: 40-200W
Sensitivity: 87dB 1w 1m
Art SLA-2 power amplifier
Toroidal transformer
200W per channel @ 8 ohms
560W bridged mono @ 8 ohms
Response: 10Hz-40kHz within +/-.5 dB
XLR, Euroblock, 1/4" inputs
XLR and 1/4" outputs
Includes tamper-proof faceplate
SmartFan silent cooling system
1U rackmount chassis
Discrete linear design
All steel enclosure
The other amp i was looking at was the:
Samsom Servo 600
Output Power:
Input Sensitivity: 1.24V (4 dBu) @ 8 Ohms
Input Impedance:
Frequency Response:
Total Harmonic Distortion (THD): 0.04%
Or can anyone recommend an amp that would be better suited to these monitors.
Any help would be much appreciated
PMC DB1I monitors
Impedance: 8 Ohms
All steel enclosure
Samsom Servo 600
Output Power:
- 8 Ohm Stereo: 225W (Per Channel)
- 4 Ohm Stereo: 300W (Per Channel)
- 8 Ohm Bridged: 600W
Input Impedance:
- 15 kOhm, Unbalanced
- 30 kOhm, Balanced
Frequency Response:
- 20Hz - 20kHz (0/-0.5dB, 8 Ohms, 1W)
- 5Hz - 60kHz (0/-3dB, 8 Ohms, 1W)
