Z
		zenpicker
I have a good large diaphragm condensor (ADK A51TC) and have ordered a good small diaphragm condensor (Neumann KM184).  What's the optimal way to place these for miking solo acoustic guitar?
Having worked with stereo pairs of SDCs (Oktava MC012s), I'm well aware of the need to avoid wave cancellation effects, but given the different audio footprints of an LDC and an SDC, what considerations should I be aware of? How do their catchment areas compare with one another? Where would the points of signal cancellation likely be found?
My assumption is that the SDC will target the lower bout or saddle, while the LDC will target the 14th fret, maybe set back a little farther than the SDC. I've done this setup with an Oktava as the SDC and generally it works well, but the Neumann is a better mike with a more pronounced high end (so I hear), so I want to get it right.
Of course the ears are the ultimate test, but I thought it was worth tapping the collective wisdom here to get some guidance. Any thoughts, pointers, things to watch out for?
