Hey guys, I'm using a Blue Bluebird microphone (old version, not the SL one), connect to the SSL2 and directly to go to Logic Pro X
There is some noise coming out when I just started to record, below is the noise that I captured.
From the beginning of the clip, I turned on the 48V on the SSL2, then you will hear some noise, that I raised the gain from 0 to 10 slowly,
at the end, that become silent, because I turned off the 48V, but after this, a short noise is coming out~
Is that a humid issue? But I always put it in a dry box....
And I seldom use this microphone, before I'm using the scarlett 2i2 (few years ago), there is a "pop" sound when I started to record (like the click/metronome),
then I put it in a dry box to let it dry, after that, everything is fine...
But this time I can't figure it out....
