My head blew up
  • Thread starter Thread starter thenextbigthing
T
thenextbigthing
Member
I was jamming the other day and my amp head just stopped working, the light was still on, but then the back of that bitch started smoking up the room, and stunk like shit. Im just wondering what would have caused it, it smelld like wires and stuff burnt, was it the way i set up my rack stuff. I had my guitar to my pedal board, hooked up to a pq-3, hooked up to my amp input. ???????????????????????????????????????????????????????
have you recently changed the fuses and put a wrong one in??? or buy it used??? maybe someone else put a wrong one in, you got some bad voltage and bam...it didnt break and killed it...
if you smelled plastic, more than likely, something is fried...take it to a pro
What tune were you playing when it blew?Have you stopped to think that maybe your amp thinks you suck,and decided that it would no longer work for an asshole?Maybe the amp is a real POS,thus explaining the need for
devices that sound like games a teenager would play on a computer.
hey i had a bad marshall straight from the factory do this...
and years later, a moron tech throw the wrong fuse into a boogie 50/50
0_o
Did you have any cables running into a desk, possibly improperly? I've had this happen to me before at a venue where someone plugged a cable from my head into an insert channel by accident (stupiddddddd) because they got the line-in and insert mixed up and realised "oh there's no sound" so they pulled it out and BAM, all the circuitry went... It was a marshall head last i remember hahaha.
Power transformer, most likely. The bad news is that it is probably the most expensive single component in your amp.
And yes, unfortunately, this is the Voice Of Experience speaking to you. I feel your pain. ;^)
my amp burned up a couple years ago in much the same fashion - my drummer called me, told me that him and the singer had been messing around and playing with my rig, and then the amp toasted itself
i went over and opened it up, only to see that the plug that attached to the main board from the power board had completely fried...the plug and wires were done for, and there was a big-ass hole in the board where the plug used to go in. everything was black, and stunk like total ass.
i took it to an extremely reputable tech, who fixed it in about a week by hard-wiring the wires to the board...he then told me that it blew up because the hum balance was all out of whack. i didn't know when i got the amp(and still don't, really) what the hum balance knob on the back was for, and had been dicking around with it...and well...yea. poof! he also set the hum balance properly, and put in a couple of transistors between the heaters and the board to keep it from overheating and torching its innards again.
moral of story - there's a million reasons why your amp could've fried, but there's a good chance that you fucked with something that shouldn't have been fucked with. tube amps are finicky creatures, sort of like women...you might have all the big stuff taken care of, but one little mistake, and you can blow the whole thing. make sure to take the amp to a VERY knowledgeable/reputable tech if you want it to be fixed properly, because i've heard a million stories of amp repairs gone wrong.
I keep thinking of that one movie where people's heads blow up.
Sheppard B
You are a total idiot to respond to somebody with a legimate question. I really don't think we need idiots like you on this BBS. What a JERK!!!!!
LOL! That's hilarious!
I'm glad the story didn't end up like this...
Rick Fitzpatrick said:
Originally Posted by RICK FITZPATRICK
You're joking of course? Imagine curtains catching fire. Which will burn off quick. However, imagine another scenario.
You have 12 fabric covered panels on the walls, and 2 fabric covered clouds on the ceiling.
Like most HR enthusiasts, you also have designed your room for recording, not safety. You also didn't get a permit/inspection when installing the electrical. Not being an electrician, you inadvertantly place two out of phase circuits in the same room. One of these is a 15 amp lighting circuit fed from an adjacent room outlet, tied with an outlet in the studio to feed the musicians equipment. You also didn't use a lever latchset on the door, but managed to put a double keyed deadbolt which you lock when recording, but do not think ahead and remove the key.
You have 4 people, a set of drums, 3 amps, your recording gear and various other things in a small room. Unaware that the circuit you tied into for the lights is also feeding a freezer in the next room which was installed by the previous owner also without permit. However, he tied in the circuit with a j'box and a 14 gauge extension cord. You must pass through this room, which the previous owner added to the house, to get into the studio.
The musicians are playing, you are recording, and the freezer compressor kicks on. Unbeknownst to you, the circuit is holding, but the 14 ga wire is overheating at a cable clamp in the J box. At some point, the extention cord vinyl jacket melts, and the conductors short together and arc...oops, the previous owner didn't put a cover on the J box either, which allows the arc ignite the adjacent wood chips from drilling a hole in a stud for the wire. Now, when the wires shorted, it throws the circuit breaker that feeds your lights as well as the musicians equipment too. The music stops as does the light. Well, this is a studio, and you have no windows, but you do have total darkness now. Hmmm, whats going on.
You tell the musicians to hold on while you check the breaker. You fumble around looking for the key to the deadbolt. Hmmm, its not in your pocket. Now what did you do with that key. Hmmm, 5 minutes pass while you fumble around in the dark trying to feel for the key you set someplace. Wait,. what is that? You smell something...Meanwhile..
the fire easily climbs the stud, as he also didn't bother to nail in a fireblock in the wall. Nor did he use drywall as a shiething. Since this was "only" a utility room, he used 1/8 ply with a vinyl coating. Ahhhh, but you used 2 layers 1/2" drywall with a 45 minute fire rating each on your side of the wall. Now the fire easily burns through the ply and spreads. The whole wall in the adjacent room is now on fire, as the vinyl melts filling the room with viscious hot smoke which is now spreading to other areas of the house. Now it burns through the 1/8 ply ceiling, and fills the attic smoke, and the structural framing catches fire now.
Meanwhile the musicians are smelling smoke and begin to yell and panic, as they are in the dark and get disoriented. One finds his way to the door and grasps the knob which is now 400 degrees, blistering his hand. He screams in pain, turns and trips over a cord and falls, blocking the small aisle between the drums and an amp. The rest of the musicians are totally panicing as are you. Now you find the key, but are unaware of the fire burning through the wall at the joints in the drywall, which were not even taped. Simply covered with mud. The fire now reaches a nylon fabric covered absorber panel. It burst into flames, lighting the room, while all the musicians are beginning to cough and scream, which no one hears because of sound Transmission loss construction. Now the fire jumps to the ceiling panels which allow melting nylon to drip on the people below, lighting their clothing on fire, and sticking to skin. Screams fill the air while you try to get to the door..which is blocked by the others...you scream to get out of the way to unlock the door, which you are unaware is engulfed in flames on the opposite side. You make it to the door and try to insert the key, only to burn your hand on the deadbolt housing...you scream as you try to insert the key without touching the housing again....luck is with you, and the key turns...but now you have to grab the latch handle and turn it..without thinking you grab it.......screaming again...if only you had used a LEVER latch set..........you now are being overwhelmed by the others, who are clamboring over you to get out, one who is now screaming from the clothing on fire..wrestling on the floor to put it out...total panic...you grab the handle again from total fear regardless of the heated latch..it instantly burns your hand but you quickly turn it, only to have the backdraft of the fire blow the door open and knocks everyone back....there is no escape...the room is totally engulfed in flames.........
Improbable if not mpossible you say....think again.. people die every year from Murphy induced scenarios mostly caused by non inspection of electrical and ignored building code construction. Add flamable materials on walls and ceilings and you add to the probability that someone may get hurt, especially in closed off spaces with only a door for egress, such as a studio. No wonder you have to get a special permit for NO WINDOW construction.
Murphy is ALWAYS around, just waiting for the slightest lack of forethought,
laziness, or just plain stupidity. Just ask those who buried their loved ones because of it.
fitZ
And hey, the title of the thread is "MY HEAD BLEW UP" and that's pretty ambiguous.
Kinda like the time I put LPs up for sale and some people thought they were Les Pauls instead of Cher albums.
You deserve to be punched in the balls. Apl's good people, he sent me a cd with fan noise on it.
I think APL is gassy. But I really don't care. He saw Scanners.
You were responding to SheppardB!
That wasn't nice either.
He still deserves to be punched in the balls.
