K
Kellie's Dad
I just bought a PC with Athlon 1400, 60 G. Maxtor 7200, 256 mg. SDRam, W98SE, and Audio phile 2496 along with SB live Value for midi...... I bought what I could afford at the time and it included a PC CHIPS Socket A with a lot of onboard crap. I've been having crash problems and the company will take back this motherboard and let me upgrade it. What should I get without spending too much more money.
So far I'm only using Cakewalk HS 9.0 and early version of Cubasis.
Would an ASUS A7SA-266 with onboard audio be okay? Should I look at RAID even though I don't understand it? Should I go to one that use DDR Ram instead?
My options are:
ASUS A7V 133-c WA (w/audio, can be disabled)
ASUS A7A-266 WA
or using DDR;
ASUS A7A-266 WA
ASUS A7M-266
Help appreciated.
My options are:
ASUS A7A-266 WA
or using DDR;
ASUS A7A-266 WA
ASUS A7M-266
Help appreciated.
The heat issue concerned me a little and plus I felt it'd be best that I get a board that can take more processor than what the Asus could so I changed my mind...now I plan on getting the Abit KR7A (it's only about $30 more than the Asus). And I know probably as much as you do about RAID. I guess if you still wanna stick with the Asus board make sure you keep it plenty cool! Good luck!
