R
remco
StudioJunky
Hi all
Wat needs to be done for mainteneance a old console (1983 AH 2416)
and what does is cost
Tnx Remco
Tnx Remco
There are definately things that any user to do on their own concerning maintenance. Recapping is one that really should be done by a pro though. It requires a lot of really touchy soldering that can absolutely destory a console if proper care and technique are not used. I would NOT reccomend you recap your own console unless you have a lot of experience doing it. When a console needs to be recapped, it can sometimes be hard to tell. As the capacitors wear out and die, things can be drastically different, not work, or also be very subtle. It can be hard to tell when the differences are somewhat subtle. Old caps can make preamps noisier, have less gain, and more "dull" sounding. Bad caps are a little easier to tell since often features can actually stop functioning, and the caps themselves may even be very swollen, or have visible leaks, or even be completely blown up.
Every person may charge very differently from one another. PLus, the parts for your board may be either more or less than others. Also, your console may not have as many caps as one like mine (TONS of caps).
