C
cky4987
Looking to spend anywhere from $500 to $1000 on a microphone for hip hop vocals any recommendations? also i know this is a noob question but is a mic pre really needed? and will it make it sound a lot better?
i would say a NO on the preamp, going by experience the preamp does little in way of sounding BETTER, at least for hip hop vocals, the idea is that you want your track to be as clean as possible, all a pre will do is color the sound. You can get a solid state pre that will do little do color your sound but also will not do you any good if you are only using it for vocals, i also am into hip hop and that is how i roll. Oh, and this may depend on how good your pres are on your audio device, which ever it is that you are using. You'll want to concern yourself with the frequency response of the mic keeping in mind what frequencies lend to clarity and which ones lend to sibilance. The frequency response will be a factor in how clear your vocals come through. If you got a grand to spend you should be pretty satisfied in almost any mic you get, check this as prolly your highest end mic at that price.
http://pro-audio.musiciansfriend.com/product/Neumann-TLM103-Microphone?sku=271399
NOTE: I aint no expert, but i hope i served some help
It's true, you ain't.
Preamps do matter, and with that budget, you might want to consider something like the SM7 (I hear everyone's doing it) with a good pre, FMR RNP, P-Solo, Grace 101, etc.
I wish everyone here would stop using the term "color" as though its a bad thing.
Define "color"?
What does an artist use to paint with?
The U47 has one of the most colored sounds in the world! So do Neve preamps! What beautiful color they impart too!![]()
it's not a bad thing, i didn't use it as such, i was just saying that for his situation, Hip Hop vocals, he may want a more clean sound, it was something to consider, for instance if he did go with a preamp also, he may want one with a solid state/tube blend rather than a straight tube amp that may give him an undesirable sound for his vocals, if you go clean, you can always make adjustments later, but if you buy a pre and don't consider the different options you may stick yourself with something you really don't need or want,
AND yes, what is your signal chain, that would make most of this talk unnecessary
You can't NOT have a mic preamp. It's not an option. You can't plug a microphone into a line input.
no shit huh, i'm going to bet that he's got an audio interface connected to his computer that has built in pres, even the very cheapest devices do now, which is agiain why i said he should be lincluding that info
sm7 or RE20 also pick a preamp with a fast slew rate you need it to catch tranits and be more musical in hiphop
