		Squiksilvery
Hello,
I have my drum overheads (pencil condensers) straight down, at the extreme edges above the kit, about 8ft up (ish), howver this is in the studio where drums are played with no bleed noise.
I've been asked to record a band live... I fear this method will havee too much bleed. What is the best technique for overheads in live situations?
Cheers
Cheers
. also, have the band set up so there are no amps facing the kit mics, like, at all. this SHOULD cut down on your bleed quite a bit, but if someone else here knows some better condensers to use for that and you have access to them, it would probably be better to use them.
