I need to know how to mic a leslie speaker for live recording and studio and also should it be stereo or mono panned left or right. Are there any gospel engineers out there that could help me ?
A keyboard player that I worked with years ago used to put a SM 57 on each horn and panned them hard left and right for LIVE performances. I'd do the same for recording but I'd play with the pan to find out where it sits best in the mix.
People do it different ways. The way I do it is mic the back of the Leslie, one mic on the tweeter and one on the woofer. Not so close that you hear the wind blowing. I use cardioid, not super- or hypercardiod, so that the mics hear the speaker coming around better. How close depends on your room and the sound you want.
I've tried recording the Leslie in stereo, but I get motion sickness when I listen back...
I always use a single mic about 4' away from the cab about two thirds the height of the cab from the floor. I've used everything from a Shure 545 to AT4033's with great results. I find it easier to set it in a mix with a mono mic.
Me too.................some guys disengage the bottom speaker so it will not rotate and mic the top. Do a google search for leslie and you will find some other options.
His Leslie had a big horn on the bottom that rotated in the opposite direction of the smaller horn on top. Now I don't know if they've changed over the years but this was back in the late 70's / early 80's.
Well yeah .... I suppose technically the lower unit could be called a horn. It's actually a rotating woofer enclosure. The woofer fires down into the enclosure which spins so the opening is rotating.
I borrowed my accordion player friend's Cordovox Leslie and amp.
Quite an interesting thing, but it sounds authentic!
Seems to be some kind of weird crossover. (Some?) Bass comes out of the amp while the rest comes out of the Leslie. It also has unusual grill positions for the speakers with no opening on the back.
Will be interesting to mic, but it sounds good, so hopefully I won't have a problem throwing some 57s on it.
