Calwood said:
			it kinda makes things more confusing,..but,..usually when I get totally lost thats when things start making sense. Thanks for the help brother.
OK I'll try again.  First off, don't worry about the long list of overtones.  As I said, that was just for reference.
Let's say you have a piece of gear, a preamp we'll say.  Run a test tone through it at 1 kHz.  Using a spectral analyzer, look at the frequency graph.  If it has low distortion, you'll see something like a single peak.  If it has pleasing distortion, like nice tube gear, it will show a large peak at 1 kHz, and a couple of small peaks at low, even order harmonics (2, 4 kHz for example).  A bad piece of gear will have the big peak, but a fair amount of random-looking small peaks here and there.
Now, an instrument is much more complex than a test tone.  It will have its own series of harmonics that you are seeking to preserve.  If you add distortion to that signal, the primary tone will still be heard, but the overtones will be muddied up by the harmonic distortion of the primary tone (and the distortion of the overtones themselves).  Effectively they get lost, and you're wondering how you can add them back.
The answer is to start with a better signal chain.  It doesn't have to cost a fortune, every step up the quality ladder helps.
I think once you upgrade your gear as you say, you'll suddenly hear all these harmonics you've been missing.
As for adding harmonics, sure you can do that, it's a cool effect, but it is an effect, which means that it doesn't replace a quality recording in the first place, and it should be used with discretion.
