E
equinox
I use half speed recording quite a lot mainly on analogue synth to achieve high percussion / retro sounds and similiar
effects (Les paul) as done in the 60's. Midi double speed technique doesnt achieve "that sound"
I'm using Sonar 7 but processing is very very slow when doubling speed on recorded tracks to monitor end results.
I need some sort of old fashioned tape machine with 2 speeds (alla Les Paul technique) to use as a quick monitor, is there anything out there digital that will do the same job? I only need it to monitor progress not in the mix.
thanks
thanks
