M
Mr Nice
I thought I would post this up for this site. It would be cool if it became a sticky.
My studio houses both balanced and unbalanced cables and I dont get excessive noise (if any) in my recordings. I happen to make sure of 4 things.
1. Separate your audio cables from your electrical cables.
2. Make sure the polarity for audio and electrical cables are the same on each end.
3. Make sure your equipment is well grounded. Make sure the house is well grounded also.
4. Keep the volume on your source instruments a little under max when you record. If the signal is too low use the gains on the mixing board.
Follow these simple steps and your recordings can possibly be a bit cleaner.
NOTE: These tips will not work if you have a cheap sound card that will inevitably produce noise.
My studio houses both balanced and unbalanced cables and I dont get excessive noise (if any) in my recordings. I happen to make sure of 4 things.1. Separate your audio cables from your electrical cables.
