MarkoPolo
As everyone knows there are many Amps and guitars that are noisy, What are some fav gear and or tricks besides gating that some of you have found usefull in dealing with recording such guitars Amps etc ??? Thanks
 .boomtap said:Don't record around CRT monitors, or you will never get rid of the noise. That is all I know, aside from using a Variax and A POD which will be as quiet as possible.
Bruce Miller said:LIFE IS NOISY! GET USED TO IT! Are you making music or sterile sounds? While you can get very clean sounds that are quite musical, human imperfections can be more believable.
thediscoking said:Instead of defaulting to "fix it in the mix", take care of the problem in the guitar rig. Getting better pickups or investing $100 in a Boss noise supressor is so much easier and it is a permenant solution.
