N
		Noplasticrobots
On page 28 of the manual for th DP-01FX it states:
"On the DP-01, you can set the frequency at which the EQ HIGH and EQ LOW
controls work; individually for each channel."
I just want to make sure I'm understanding this correctly. If I want to boost or cut, let's say 700 Hz in the low end, I would set the Low knob to 700 Hz and proceed to boost or cut from there?
It sounds painfully obvious after typing this out that this is how it works, but I might as well ask to be safe.
