Dmp2
  • Thread starter Thread starter Dj17
DMP-2 doesn't kick out quite enough phantom power when running two condensers, simultaneously. This is only going to be a problem, by the way, with some mics (most condensers, actually, will be fine).
It also doesn't have any means of padding the input the way the DMP-3 does, so on very loud sources, you're either going to need a mic with a pad, or you may have to purchase some of the Shure attenuators (something you should have anyway).
Other than that, they're mostly the same.
Mickster
Replies
7
Views
1K
Sky Blue Lou
Sky Blue Lou
subvibe
Replies
6
Views
997
TalismanRich
TalismanRich
FrankD77
Replies
57
Views
2K
FrankD77
FrankD77
D
Replies
2
Views
7K
rob aylestone
rob aylestone
