Cubase plugin out of window AARGH!
  • Thread starter Thread starter jackjameson_
J
jackjameson_
Hey guys,
i was mixing a vocal with a standard cubase compressor.. then i accidentally moved it out of my screen.. so i only can see 1/5th of the pluggin.. i cant move it back into my screen.. never had this with my mac.. but now with windows.. the bugs.
ive cubase 7 elements.
First thing to try is to scroll those page things at the far right and bottom of the Cubase project window.
If that does not work, then I would ask if you are using two video monitors with different resolutions?
If so, then change the resolution on the offending monitor, move the GUI of the plug, then change it back.
I am betting it was the first choice. I have pulled hair out from similar situation myself in the past...
Lemmy know if that works for ya. :)
The easiest to get s lost plugin back is to select it in your DAW, like you normally would for it to show up on the screen. Don't click the mouse anywhere else. Hit ALT & SPACE BAR then select Move. Use the Arrow keys to bring the offending plugin back onto the screen.
This also works for anything lost to the side. :thumbs up:
