B
		BrianCRX90
Thank you for the previous help, got another question.
A couple quick questions. I've read some articles online about putting effects such as compression and eq on the master before the mixdown. Never really occurred to try this. I've been working on getting a mix around -6 to -3 which I did then adding effects on the mix. Is there any incentive in putting compression, eq...limiting on the master? If I did this, well then there isn't much to do except some light noise and hiss removal and dithering so I can put it on a cd.
Since I'm here also I found a very good vst multi-band compressor that also has a built in limiter. Is there any incentive vs using a separate compressor and separate hard limiter?
