ENIGMACODE
Hello again to all
In regard to drywall installation, I've gotten some valuable information in the past from: Rod Gervais,Innovations,Rick,and Frederick.
Rod Gervais outlined the CORRECT method in installing drywall:
"Install the ceiling layer first - leave this 1/4 to 3/8" from the wall framing. Caulk this joint.
Install the wall layer...... leave this 1/4" to 3/8" from the wall/ floor/ ceiling - caulk this joint...... repeat this for the remaining 3 walls......
"Make certain that at the corner joints you are going to tape that the caulk is slightly recessed in the corners."
With the above being said, not to beat this horse again, I still have a few questions:
Was Rod saying that even in the inside corners of the walls (where the 2 sheets of drywall from each wall meet each other vertically), that this vertical seam ALSO needs to be separated by that 1/4" gap?
And one more question:
The 'TYPE' of caulking to be applied before the taping occurs in all of those gaps - Standard Latex Caulking ok?
Thanx again guys ..
Best Regards
Mike Fraticelli
ROCKON@ucwphilly.rr.com
Thanx again guys ..
Best Regards
Mike Fraticelli
