Can gear go bad?
  • Thread starter Thread starter Jackrip
J
Jackrip
I have a relatively new set-up, but I havent recorded or used it in anyway for a long time. Well today I try to record and the vocals come out like complete shit.. is that normal, or did I somehow screw up my equipment by not using it for that period of time? I paid alot of money for it so I hope its still okay. :(
the expiration date is clearly printed on the bottom of all gear.
if your gear has'nt expired, it could be your ears, mood, different room, mic position, misalignment of the moon with pluto, etc., etc.
No astral body wants to align itself with Pluto now, since it's been downgraded. Nobody loves you when you're down and out. :(
I've find that 99% of the time people think their vocals sound like shit is because they sing like shit.
So true, so true.
I still can't get over the sound of my voice recorded, because I know it doesn't sound like that in my head! :o
asisde from the many jokes
the title of your thread brings to mind
how old is the gear?
capacitors can go bad after a period of time
even with no use
and if one were in a key position
in your signal chain
it could degrade the sound
it's unlikely that other components
would go bad in equipment
that hasn't been powered up
I see a video....Good Gear Gone Bad... How lond sinse you've used it?
notCardio said:
So true, so true.
If you don't like the sound of your voice from a recording, that usually points to a poor choice in microphone. The sound through your head is a combination of direct sound and indirect sound through your skull, so it will never sound exactly like it, but with a bad choice of mic, it will sound radically different (i.e. bad).
So what kind of microphone are we talking about, and what type of voice do you have?
even with no use
My gear is less then a year old. The vocals were pretty clear before, and now they peak way too soon and they distort, and even with the gain on my preamp all the way up, the vocals are low. It can just be a setting thing on my compressor which is what I originally thought, but then again, I didnt change any settings from the last time I recorded, so that got me thinking.
You might have stored the mics unproperly...good condensers need to be airsealed and kept from moisture or the capsule will go straight to hell. :rolleyes:
Sounds like a gain staging problem or, careful here, there's a chance you are singing into the wrong side of the mic. We've all done it once... well YOU"VE all done it once....
Its the right side of the mic lol...
I am fearing that, that is what I did, I didnt store it at all, it was on the mic stand the whole time... although there was no mositure involved.
You might check the mic cable to the microphone. It may not be making a good connection on one of the pins and you aren't getting a full signal, only half of it. That will definitely cause low output and phase problems with the signal!
There's moisture in the air.
If the gear is a year old it should be working fine, even with a layoff during that time. Gear doesn't really go bad like what you are worried about. Gear has to be abused or neglected in a serious way for it to cease to function properly.
You might try swapping out cables. Or just pull the cables out and then re-insert them.
Bingo. There IS moisture involved, more than likely. There are threads about drying out mics with a standard lightbulb. Bet this does the trick. Hope so.
Uhhh... I can check with some folks on this, but I don't think there is any general consensus on this as a strict requirement. It probably varies a lot, depending upon what the capsule and diaphragm materials are and how they are affected by moisture and, obviously, moisture levels where the mike is kept.
My AT 4050 is rarely off of its mike stand and it's still working great after, uh, a number of years... well, at least ten. I do keep a plastic cup over it (except when it's in use!) to keep at least some of the dust in the air from settling on it.
Or genetic parents. :(
Get the compressor out of the picture to reduce the variables to just the mic and the preamp (switch the comp off and anything else but the pre if it's a channel strip). If it still sounds bad, try another mic, or another pre (mixer channel will work). Isolate the problem.
I was thinking of an old Van Halen song... :cool:
War
themindwillnotletgo
Replies
38
Views
4K
themindwillnotletgo
themindwillnotletgo
antonstudio
Replies
7
Views
1K
PorterhouseMusic
PorterhouseMusic
