B
BigHighLonesome
Hello All,
As some of you are aware I have recently built a house and I'm planning on putting a home studio in part of
my basement. Well the plans have taken a drastic change and things have got a bit smaller (12*16). I will be moving in on the 26th, and I have have my PDI friday, in which I finally get a chance to take proper pictures
of my basement. I couldn't get out there this week at all, and I know a couple of you are waiting to see these. I apologize. I have made a new post to reflect the new design and direction.
With that being said, I have had to completely re do my design from scratch.
This is mainly due to some last minute unforseen expenses, in which I decided to upgrade some other portions of my house.
I upgraded to an insulated garage door and put slate countertops in the bathrooms. I just couldnt build my original design without making sacrafices so I have decided to build a smaller "one room" design properly.
I have used some floorplan software on my latest design (attached) and it is to scale. I have clearly labeled everything I could. I will take pictures
of the ceiling, but I dont (shouldn't) have anything major running through it except for one register duct. Anyhow if someone could shed some light on any mistakes I might be making or can comment
on how well the sound will be contained that would be greatly appreciated. I am shooting for only 15-25dbs of leakage to my second floor (there will be one floor between the studio and sleeeping level).
The main 1st floor above the studio is Maple and will have hardly any traffic during recording. Overall this house has been consructed above code and is SOLID.
I could have easily built another 700sq/ft into the house design and afforded it , but I built slightly smaller so I could build stronger and use better materials. I can basically jump up and down in my living room
and hear (not feel) a very, very tiny "thud" in my Bedroom, and thats with NOTHING on as far as TV's ect.
Details:
Walls/Ceiling/Floor
South/West/North
These walls will be framed by licensed framers/me after the 26th.
- 2*6 Plates (2*4 staggered studs)
- Single (8*4*1/2) sheets of Sheetrock on each side of the wall with 6" batting of Roxul sound and fire insulation (Rockwool).
The SheetRock that faces the inside of the studio will be mounted on resilliant channel.
All joints sealed with acoustic sealant.
East
This is a perimiter outside wall that has been pre framed and drywalled/taped. I am planning on unscrewing the drywall and reworking this section of the basement.
- 2*4 Framing (original framing being kept)
- Single (should I go double thick?) 4*8*1/2" Sheetrock with with 6" batting of Roxul sound and fire insulation (Rockwool) retereofitted to get into the 4" space.
The SheetRock will be mounted on resilliant channel.
The rest of the stuff on the walls in the diagram are owens corning 703 ridgid fibreglass.
The rolling wall baffles will be 4*4 sections:
The cutaway would look like:
Ridgid fibreglass - Sheetrock - 2*4 frame/Roxul insulation - Sheetrock - ridgid fibreglass on heavy rubber/locking casters. The whole baffle being wrapped in "gold" nylon.
Question: Is this a three leif design? Is this over kill?
Ceiling
Double thick 4*8*1/2" Sheetrock on resilliant channel with roxul batting stuffed into the ceiling joists and insulation wrap/roxul
heavily around the one small register duct going through the ceiling.
Acoustic sealant in all joints.
Floor
North West corner will be floated on 2*4's for drums and amps and anything else thats going to making a lot of noise.
The rest of the floor will be laminate over vapor barrier/small insulation (asphalt paper?).
Questions:
- Need a good link on how to install my resilliant channel ,and any advice would be appreciated.
- Need a good link/advice on building the floating floor section. Also, is it worth it to only float a portion of the floor? Will it increase sound deadening of the drums? In this case thats my goal of this floating floor.
Also, how does this stand up for sound proofing. Is my 15 - 25 db goal (On the second floor) a reality ?
BTW 3/4 of the basement walls are all freestanding and do not join up against other rooms/stairs/neighbors/garage ect ect. The 1 East wall is an outside wall so the layering would be :
Sheetrock - Resilliant - 2*4 filled with Roxul -- Cement foundatation, entire wall submeged underground except the top ft.
Hope you can help.
Details:
Walls/Ceiling/Floor
South/West/North
East
Ceiling
Floor
Questions:
Hope you can help.
