cincy_kid
Active member
I didn't know if I should post it here or directly in the Sony Acid forums but I figured it was a question that could be applicable for many different recording programs so here it goes.
I use Sony Acid Pro 7.
In the past, when I was recording tracks (lets use guitar tracks as an example), I would play all the way through the song on 1 track and do the same thing for 3-5 tracks so I would have 3-5 different "takes" of that track all on separate tracks. Then when it was time to mix, I would listen to all of the tracks and lets say the beginning part was best on track 1 but the middle part in track 2 sounded better. So I would erase the middle of track 1 and erase the beginning and end of track 2 so that when I pressed play, I would get the beginning of track 1, middle in track 2 and the end back in track 1. That worked well on vocals because there are breaths and pauses in between sections. Harder to do with guitar when the previous chord is still ringing through the chord changes.
Yes, I am sure there are some of you laughing at me by now, but that's the only way I knew how to do it.
Then I discovered "punch in recording". That enables me to just do 1 take of the guitar track and if I mess up the middle, I can just select the middle in the track, and go back and record the middle over and over and it makes new clips for each take and I can choose the one i like the best when I am ready to mix again. Again, easier on vocals for the same reason I mention above.
Now, that brings me to my question. I have the guitar track recorded and the song has 3 verses. The first verse sounds good but the other 2 I played a bit more sloppy. So I want to take the first verse, copy it, and paste it over top of verse 2 and 3 so that all 3 sound equally good.
Am I able to just paste over top of the existing track? Also if its not lined up exactly perfect, you will hear where it "jumps" a little bit making it sound like crap. Do I just use some sort of faders to blend one into the other? Is this even the best approach or is there an easier way?
thank in advance for any advice!
