M
marshall409
Active member
I'm back again!
Finally started my long talked about work on my basement. Stripped the walls and ceiling completely...bare foundation walls are painted. Concrete floor is going to be either painted or vinyl tile to keep cost down.
I've got a huge space here...rough 24x20. Divided down the middle by a metal support beam complete with annoying pole in the middle of my room.
Anyways the only part I have yet to decide on is the roof. I wanted to do the simple fluffy pink insulation+fabric covering idea to complement my hard floor, but my mom said shes not letting me do anything unless its going to stop sound at least a little bit. So i've come up with a few ideas from some research:
1. Seal up the floor boards with a layer of drywall or MDF and caulking right up in between the joists and then do the fabric/insulation roof
OR
2. Seal up the floor boards as above, then resilient channel or rubber pads on the joists, then a layer or two of drywall (if a structural engineer approves it of course).
Now, I'm not going all out here. I will not be able to do any serious modifications or treatments to the HVAC system and my room is probably not going to be perfectly sealed in other areas. But I know that either of these options will help A BIT and thats all I'm looking for.
My question is, will the the first idea help significantly less since I'm only adding mass to the already exisiting leaf(the floorboards)? Will the second one be well worth the cost of material and labour?
Any other cheap and somewhat isolating ceiling ideas would be greatly appreciated.
Thanks guys,
Adam
OR
Thanks guys,
Adam
