A
Autist
Below is the frequency response graph from the Rightmark analysis that I did on my AP 2496. I disconnected all of the case fans, turned the CPU fan down very low and moved the card further away from the graphics card but have been unable to get any better results (they remain consistent through every test).
All tests were done line out to line in.
Frequency Response Chart
This is the summary from the test:
Frequency response (from 40 Hz to 15 kHz), dB: +5.19, -2.31 Poor
Noise level, dB (A): -97.0 Excellent
Dynamic range, dB (A): 96.0 Excellent
THD, %: 0.0007 Excellent
IMD, %: 0.0046 Excellent
Stereo crosstalk, dB: -97.2 Excellent
IMD at 10 kHz, %: 0.0051 Excellent
Does anyone have any idea what the problem is, since I have ruled out case fans and the CPU fan (as much as possible without actually removing the fan or slowing it down so much that it is ineffective)? My friend thinks that perhaps the card is bad. Also, the large "hill" on the bass end side of the graph that starts around 350Hz does show up in spectrum analyzers when working in a DAW (even without recording anything through the analog inputs) and I have been unable to get rid of it.
System Specs:
Amd Althon XP 2400 (2Ghz)
1.5 GB DDR RAM
Asus A7n8x Deluxe Mobo
Ati Radeon 9100 graphics card
400w power supply
Windows XP Pro
Also, on-board audio has been disabled in the bios since I originally installed the AP 2496.
System Specs:
1.5 GB DDR RAM
400w power supply
Windows XP Pro
