dobro said:
"Just buy a plug-in that works and is easy to use," I say. I use the Ultrafunk compressor. It works and it's a snap to understand.
Ultrafunk's easy, for sure. The advantage of CEP's compressors, I think, is that you have the ability to compress AND expand a signal in one process. It squashes the transient peaks, and raises the signals below whatever threshold you set. If you're using ultrafunk, I think you have to have a seperate plugin to do any expansion.
But back to the original question...I have no idea. I just jack with it until it sounds good. (no, I'm kidding...hehehehe...little joke for Dobro there). The "attack and release" settings just determine how quickly the compressor starts compressing a signal (attack) and how long it squishes it before it lets it go (release). The longer the release, the more "compressed" the signal will sound...but the smoother it is. The longer the attack, the more transient peaks you'll get, because a lot of signal will go through b/f the compression starts. If you set the attack too long, it'll sound like
BADAaaaaaaaaaaaaaa. Anyway, the shorter the release, the more "breathing" you're gonna' get.
The "GAIN" section (1st one) affects what you actually hear the signal do on the way out. The level detector (2nd one) affects what gets compressed to start with. If I mess with the 2nd one at all (the level detector) I set both the attack and release really fast b/c I don't really want the signal distorted before the compression starts, b/c if it is, my settings on the 1st one might become kinda' useless.
Oh, btw...I'm a big fan of the vocal compressor settings in CEP 2.0. They kinda' got their shit together in the new version, as far as I'm concerned.
