2
2infamouz
I was curious if it's more common to send reverb to a separate track that's 100% wet (only reverb no dry signal) and then send the dry signal through a seperate track before it hits the master bus, so you can EQ the original signal and the reverb separate, or to just apply the same EQ to the original signal and the reverb at the same time? I personally prefer to EQ my reverb differently than the signal creating the reverb, but wanted to see other peoples take on this, and some other techniques you guys might have ?
