V
vintagetobes
Hey, i use a pedal through my fender Roc-pro 1000 amp. Its a hybrid amp which the fender guys describe as having tubes in the pre amp(and you can hear them rattle when you move it) and is 92 watts. Anway. by using a pedal through it, i hav no idea what level i am putting into it. I run the out of my pedal into the return of the amp on the back which skips the pre stage. Anway, i only put the effects mix up to about 3 to amplify my signal and its like, wow! Thats loud!. Which leads me to wonder one of the following:
1. my amp has tubes in the amplifying stage aswell and that explains the volume.
2. i amp driving my amp too much, and it will explode.
Help me out guys.
And also, is it a problem that the amp vibrates alot, and vibrates the things in the room and is there a way to prevent it?
Ta very much
Help me out guys.
Ta very much
