R
Randy5235
Member
recently moved into a 3000 sq ft warehouse (live there with my girlfriend and 2 roommates). they are pretty down with me doing a bit of work. the living room is about 52' x 21' x 14 . the floor is made of concrete and so are the walls. i cannot however use all that space (i wish) because my one roomate is a photographer and uses the space too (its his place) i do have the corner however and can probably use about a 20 x 20 space. I initially thought of building walls and whatnot creating a smaller room. that doesnt work for a couple of reasons. first we'll only be here 5 years tops more probably 3. second of all is cost. third the smaller room i am dealing with generally the worse the sound.
my idea was this . Basicall hanging some sort of sound absorbers from the ceiling to create the 'virtual' 20 x 20' room but i would still (i assume ) be dealing with larger room dimensions as far as sound control. plus if i hung the panels from the ceiling a could build them in such a way that i could pull the bottom up to the ceiling and they would be outta they way. I guess my questions are basically is this a sound (get it!!) idea? and secondly any recomendations on how to find my *problem* areas ... I have a BIT too much reverb happening in here (read ALOT) obviously. is there any software i can possibly get that would A: generate a tone and B: record said tone from mics to give me an indication perhaps frequency build up? sorry so long just wanted to provide as much info as possible.
Thank you ,Randy5235
PS i guess i could alway generate the tones
and to give idea i play and record mostly drums,bass and guitar (usual fair) plus ocasionally some horns and hand drums.
