X
xxmangoosexx
I just got my Tascam 246 Portastudio running smoothly, and it's been integrated as the main recorder at my home studio. I have a 32-channel board and a bunch of outboard pres and analog synths and drum machines. I'm working on a project in mono, where everything goes into the board, gets mixed, and then printed to tape. My plan is to record the same thing to all four tracks on the cassette. I've done some tests and it yields a far superior sound to recording to just one track at a time. I know it can't even approach the fidelity of 7.5ips 1/4 inch tape, but i discovered a trick on the 246 that really get's you close:
1) track the same source to all 4 tracks on your 246 with Dolby on
2) when mixing, turn dolby off on JUST TRACK 4 (you can do this because track 4 can be used for sync purposes on the 246 - check your model to see if it can do the same)
Now, you've got the foundation - tracks 1-3 of your mix with all the good noise killing dolby gives you, but track 4 becomes your 'excitement' track, because all the highs remain intact as you fade it in. Noise is minimized, because you are only dealing with non-Dolby on one track.
I've been really, really impressed with the sound!
