tigerflystudio
Hi all,
so, my DAW operates with both 16 & 24 bit. I usually record my guitars / bass etc. on my multitrack (16 bit only) then transfer them (via USB) over to the PC where I add those tracks to the 24-bit midi files I have created (synths / drums etc.). I usually convert the midi files to 24-bit WAV audio files, so I'm working with a combination of 16 & 24 bit WAV files when mixing.
So my noobie question/s?...
Q1) Is there any point transferring the midi files into 24-bit WAV's when ultimately the final mix-down will be in 16-bit audio (so it can be played on all CD players) anyways?
Q2) Should I actually be doing my final mix-downs in 24-bit, or won't they play on other people's CD players?
Q3) If I should be using 24-bit, is it about time I started recording my 'real' instruments (guitars / basses etc.) in 24-bit, too?
your help / advice MUCH appreciated
