Old 09-22-2003
Michael Jones's Avatar
Michael Jones Michael Jones is offline
Who else ya gonna get?
Michael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond reputeMichael Jones has a reputation beyond repute
Mineral Wool Density ?
A local supplier of mineral wool has 4" 8lb/cu.ft. available.
This seems much more dense than what I thought 4" mineral wool was - I thought it was around 3-5lbs/cu.ft.
Are there any problems going with the denser materal? The 8lb?
Its for an exterior, staggered stud wall frame.
"Nobody digs ya music, butcha self"
Old 09-22-2003
SHEPPARDB.'s Avatar
SHEPPARDB. SHEPPARDB. is offline
Force of Nature
SHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond reputeSHEPPARDB. has a reputation beyond repute
Mike,I dont know if it will be a problem or not.(I would'nt think so,
but you should ask John or Ethan.)I used some in certain areas
of my studio and it is not a problem as far as I can tell.I am not
finished with my studio yet,but I tested the live room with an
acoustic guitar before and after the rockwool.The rockwool
definately absorbs sound well.I only did two walls with the 4"
8lb. density,the rest I did with 2" 8lb. density.I would use the
2" where you are able to because you can get twice as much
of it for the same price as 4".
Old 09-22-2003
Thanks Sheppard.
The supplier has 4"-4lb and 4"-8lb.
The 8lb he has in stock @ $0.90/sf.
The 4lb he has to order, and its $0.78/sf.
2-3 weeks for the 4lb.
I'll have to search John's forum. Seems like I remember this issue comming up before.
Old 09-22-2003
Here's what I remember:
"When placed INSIDE a sound wall, the rockwool helps act as a trap and improves sound attenuation. The recommended density when used inside a wall is 3 PCF, same as 703. About half the air cavity taken up with insulation seems to be optimum. Heavier than 3pcf improves bass loss slightly, at the cost of higher freq's getting through. Lighter than 3pcf and the opposite happens (bass performance worse, highs better)"
-Knightfly
Hmmm.....
Old 09-23-2003
knightfly's Avatar
knightfly knightfly is offline
GrouchyOldFartOnBatteries
knightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond reputeknightfly has a reputation beyond repute
Michael, that's another one of my late-night, polarity reversal brain farts - I hope it's the LAST, since I've gotten most of my references cataloged well enough to double-check - here's a quote from the USG study I THOUGHT I remembered -
"The best overall acoustic performance was achieved with a mineral-fiber blanket in the 2.5 to 3.0 Ib/cu.ft. density range. Densities above 3 lb./cu.ft. provide more sound attenuation at high frequencies, but low-frequency performance starts to suffer at higher densities. Mid and high-frequency performance goes down significantly as insulation density falls below 2.5 lb/cu.ft. The conclusion to manufacture standard THERMAFIBER Sound Attenuation Fire Blankets (SAFB) with a nominal density of 2.5 lb/cu.ft. was based on the acoustic research, cost-to-benefit ratios, fire performance and handling characteristics." -
Note the polarity reversal in the second sentence...
And here's the link to the entire article FYI -
http://www.usg.com/Design_Solutions/...lationperf.asp
For your exterior, staggered stud frame, weaving through the studs will help in another way - usually, this causes the insulation to contact the panel in the middle of its normally free span, which will contribute to panel damping. Damping reduces the Coincidence Dip in TL, normally between 2 kHz and 4 kHz with most drywall panels. This improves TL at those frequencies (less Coincidence Dip, better TL) Damping also helps on the low end TL - HOWEVER - if you were to use the higher density insulation, it's likely that its increased stiffness would cause you to get more than just damping, more like flanking. This would REDUCE the wall's performance, nearly back to the same as using non-staggered stud frames.
Here's a page that explains this better -
http://www.domesticsoundproofing.co.uk/tloss.htm
For that reason, as well as worse bass performance, I'd stay away from the higher density stuff. STC ratings are already ignoring bass and giving us a false expectation of good isolation with bogus ratings, there's no sense in exacerbating the problem by biasing insulation performance toward treble frequencies.
Sorry about the brain fart, maybe if I tried to get more than 4 hours sleep a night... Naah, sleep is 'way over-rated... Steve
Hey, I thought this was gonna be EASY!??!
Old 09-23-2003
I guess I don't understand the premis of the observation:
If we all agree that Mass and Density are the only effective methods of sound attenuation, then the higher density material would seem to be more beneficial.
Additionally, as the density of a material increases, so too should its sound attenuating qualities; particularly in the lower end of the sonic spectrum.
However, the article seems to suggest the opposite.
Old 09-23-2003
laptoppop's Avatar
laptoppop laptoppop is offline
Musical Technogeek
laptoppop is on a distinguished road
I think there are two things happening here - mass/density and coupling. If you couple two surfaces so that they both vibrate at the same time, they will act as a big drum and will pass sound very efficiently. So you end up wanting both mass and a lack of coupling. If the insulation is too stiff, it couples the surfaces. If its not dense enough, it won't do much attenuation. If it is too dense, the high frequencies suffer. Oh man! My head is hurting!
-lee-
Old 09-23-2003
Lightbulb "I see!", said the blind man!
"...If the insulation is too stiff, it couples the surfaces. ..."
Old 09-23-2003
knightfly's Avatar
Shit, you guise don't need me anymore, I'm goin' fishin'...
Old 09-23-2003
Han Han is offline
1K Silver Member
Han has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond reputeHan has a reputation beyond repute
You might find this interesting: http://www.recording.org/ubb/ultimat...4;t=000782;p=1
