Go Back   Home Recording > Equipment Forums > Microphones
Reply    Audiofanzine Microphone Microphone News Microphone Medias Microphone Tests Microphone Articles Microphone User Reviews Microphone Classifieds Ads
Old 09-16-2003
Foo-bu Foo-bu is offline
Senior Member
Foo-bu is a jewel in the roughFoo-bu is a jewel in the roughFoo-bu is a jewel in the rough
the death of my mic?
I bought a audix D4 for my kick drum about a year and a half ago and i've only really used it once. the other day i went to use it and there was very little signal comming from it. i checked everything and couldnt hear anything unless i cranked my monitors and faders and just taped on the mic. i've never dropped the mic or done anything that would cause it to break so im trying to figure out if theres any suggestions for how i can fix this problem
Old 09-16-2003
donkeystyle donkeystyle is offline
This place sucks now. Bye
donkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond reputedonkeystyle has a reputation beyond repute
i don't mean to sound like an ass, but did u try a different cable?
This place is garbage.
Old 09-16-2003
Senior Member
yeah sorry i forgot to put that in. i tried using differnt cables that i know work, checked the inputs on my mixer, everything
Old 09-16-2003
DJL DJL is offline
Banned
DJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to allDJL is a name known to all
Have you tried lightly slapping the audix D4 into the palm of your hand a couple times?
Old 09-17-2003
Senior Member
i lightly tapped on it and heard nothing unless i cranked my speakers all the way up and had my faders at their highest
Old 09-17-2003
muttley's Avatar
muttley muttley is offline
Force of Nature
muttley is on a distinguished road
Try a different input?
da MUTT
da MUTT
LIFE IS GOOD!
Old 09-18-2003
Senior Member
i did that
Old 09-18-2003
Cave Dweller Cave Dweller is offline
Dedicated Member
Cave Dweller will become famous soon enough
it could be that either the hot or cold wire has become disconnected from the XLR connector inside the mic casing. you should be able to remove a screw, and the connector should pull out.
Old 09-18-2003
Senior Member
and then if i do that what would i do afterwards? just push it back to place?
Old 09-18-2003
MemoGtr's Avatar
MemoGtr MemoGtr is offline
Así o más verger?
MemoGtr is a jewel in the roughMemoGtr is a jewel in the roughMemoGtr is a jewel in the rough
violence is the answer
dude, that sucks. check everything's fine inside the mic or if you dont now what you're doing take it to someone who knows about it
Memo!!
Old 09-19-2003
muttley's Avatar
Force of Nature
Resolder the conection back together.
da MUTT
da MUTT
LIFE IS GOOD!
