Problems recording vocals with the SP C1 Mic.
Sometimes I will record a vocal for a tune and the C1 just blows me away. Other times, I will record a vocal and it sounds kinda distant, with lots of sibilance problems.
Mostly latley, I have had problems. I have moved my studio into a differnt room, and I wonder if this may be effecting its sound. I wouldn't think it would effect it to much, since I sing pretty close to the mic. Anyone have any sugestions? I am running it through a vtb1, and then into a joemeek compressor. And then into my VS 1880. Thanks, Rich www.richbischoff.com
http://www.myspace.com/richbischoff |
Size of room will change things also what the wall are made of.
is there a lot of metel objects near such as cymbles mic stands etc if any of what I said is a problem, a cheap way to deal with it is hang a blanket on each side of the person you are recording only if you dont have a booth with proper dampining. the blankets will shield most of the ambience caused by the room or whats in the room.
Marko |
Thanks......
To hang the blankets would be differant depending on your room.
cieling wood/ sheetrock/plaster etc. you could build two holders out of wood 2x4s making a perfect square out of four of them with two small 2x4s as feet braces 2x4s are about $2 a piece, then drap the blanket over them. thats just one way. also the reason you didnt think it helped in your situation is because you need more of an inclosure to cut out room sounds it sounds like you just had one draped over a mic stand which wouldnt do a whole lot of good.
Marko |
MarkoPolo, Thanks for the reply. What if I made a tent of sorts out of blankets and put the mike inside there and then sang my vocals inside this makeshift tent? I'm looking for the cheapest posible option. I want my vocals to have that warm smooth sound, but latley just seem to have distant harsh hi end sound.
the C1 is a bright mic and often sounds siblant..
Re: Problems recording vocals with the SP C1 Mic.
He may not have another room to use.
I have a C1 also and it usually sounds good for most vocals I have used it for, but the room I use is set up with good acoustics. The PVC idea is a good one but more expensive then wood but more light weight and would look nicer. try the tent option first if you want and let us know how it workes for you.
Marko |
There you go again DJL, praising Studio Projects for no good reason!
This spam has got to stop....... Fab ![]()
Christopher Ave Fab4Ever! www.christopherave.wordpress.com www.musicformediaproductions.com |
