Old 09-15-2003
LOPEZRECORDS LOPEZRECORDS is offline
Newbie
LOPEZRECORDS is on a distinguished road
Talking setting's @ int. mixdown (vf160)
Hello i just recorded the first track onto the cd and the sound is kinda low... Do you lower all your monitor's externally amped with own volume to a confort zone meaning halfway. Or do you shut them off completely and use phones only and if the cans are the answer to what volume level do i set them to? i know dumb question but it will beat wasting cd's and this site alone has got me pertty far. No harm in asking...
THANK'S
LOPEZ RECORDS
Old 09-15-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
I'm not sure I totally understand the question but as I see it there are two points to make...
1 - you shouldn't mix with headphones, so the level setting is kind of irrelevant.
2 - a reasonable mixing level (via monitors) is around 85dB -- this is where the ear's frequency response is the flattest, so our ear's tendency to give more "weight" to the midrange band is somewhat minimized.
Old 09-15-2003
billisa billisa is offline
1K Silver Member
billisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond reputebillisa has a reputation beyond repute
I may have misunderstood your question, but I'm going to come at it this way. When you bounce down, set your levels on the VF160 so that the L/R stereo mix levels are hitting near the top range of the display, just below peaking. Then do the same thing again when you master. How you set each individual fader is a choice you need to make, but the overall level going into the stereo mix should be near (but not touch) peak levels.
If your monitors/headphones are initially set too high, and you pay attention more to their volume than your meters, you'll wind up with a low-level final mix.
In an extreme example... you could have your monitors cranked up all the way, with almost no levels on your VF160 -- resulting in a final mix you think is loud, but is almost non-existent on the CD.
Old 09-15-2003
Newbie
Talking THANK'S!!!
Thank's im sorry i couldn't explain my self right but it seem's you know what im after and thank's for the pointer's i will give them a try but don't get me wrong more are welcome.
LOPEZ RECORDS
