Old 09-06-2003
Toker41's Avatar
Toker41 Toker41 is offline
Better Than You
Toker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond reputeToker41 has a reputation beyond repute
Bass Pod Pro?
OK,
I've about made up my mind on buying this Bass Pod Pro for $329. Anyone have any suggestions or opinons on using this (or not using this) to record bass direct?
Old 09-06-2003
grinder's Avatar
grinder grinder is offline
Force of Nature
grinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond reputegrinder has a reputation beyond repute
I have a bass pod(not the pro).The best results I've gotten have been using both outputs,( modeler and D.I.).Running both outputs to separate eqs.Eqing the modeled sound for low end and the DI for attack and clarity, recording both to separate tracks and blending.As soon as I get a bass mic I will try running the modeled output thru my Hartke(which sounds great with the A.I.R. on) blended with DI.
Old 09-06-2003
Toker41's Avatar
Better Than You
Damn, the way everyone raves about the Line6 amps, you would think you would just have to "plug it in and go".
Old 09-07-2003
Kryogh Kryogh is offline
Dedicated Member
Kryogh is on a distinguished road
Arrow for whas it worth..
I used those Line 6 preamps a few times, and, they arent bad. Sounds ok. BUT, be carefull with the unit's compressor, every BassPod/pro that came here, turned off the damn compressor cuz it wasnt getting the sound better, it was destroging it.
In fact, I even bought a BassPod last year, I used a few times, and then I sold it.
