Old 09-05-2003
vacumatic vacumatic is offline
Newbie
vacumatic is on a distinguished road
Re-amping set-up for MR-8?
I want to send a dry, recorded guitar from track 1 (for instance) though my POD, alter the signal and run it back into another track in the MR-8. What would I need to do to achieve this?
Old 09-06-2003
Ed Dixon Ed Dixon is offline
1K Silver Member
Ed Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond reputeEd Dixon has a reputation beyond repute
Not sure there is a way to do this with just the MR8. I just run guitar through my POD before recording in the first place.
Ed
Old 09-06-2003
Dexter411 Dexter411 is offline
Junior Member
Dexter411 is on a distinguished road
Try arming Track 2-- plugging the headphone out through the POD and then back into it and recording.
Old 09-07-2003
Newbie
I have tried that and I got nothing but feedback. Really beautiful feedback, but NOT what I was looking for.
Old 09-08-2003
mrx mrx is offline
Force of Nature
mrx is on a distinguished road
Looping like that through the headphone jack won't work, since the track you are recording also goes to the headphone out, causing your feedback.
Might be able to pan the first track hard left, and the recorded track hard right, and use a mono cable from the headphone jack (or one of the line outs) so that the track being recorded is not sending a signal to the line it is recording from.
Old 09-08-2003
mrx mrx is offline
Force of Nature
On second thought, you could just copy the original track to a PC and play the wav back from you sound card output, through the POD, and back into the MR-8. If you use a tempo map, you could also use MIDI sych (and play the wav back through something like cakewalk that will synch with the MR-8) to keep the new track (from the POD) in sync with the rest of the tune.
Old 09-08-2003
Junior Member
Wouldn't it work through headphones if you turned the monitor level on the tracks down? I mean, those faders control monitoring -- not recording volume.
