Old 09-03-2003
Toad Rush Toad Rush is offline
Senior Member
Toad Rush is on a distinguished road
Level loss recording VTB-1 -> Delta
I am having level loss between my VTB-1 and my Delta 44 when recording my amp(guitar).
I asked my friend about the level loss i was having in between my VTB-1 and my Delta 44 and he said that it was because the VTB-1 had consumer outs, and the delta 44 had pro ins. Can anyone confirm this?
Right now i have to go SM-58 -> VTB-1 -> PodXT -> Cooledit, because if i go SM-58 -> VTB-1 -> Delta 44 -> Cooledit i get a horrible level loss that i have to boost about 20db to be able to hear it and by that time it sounds like crap.
Normally i wouldn't have a problem with using my POD for this, but since i want to use it for effects, this workaround removes that option. Is there anything else i could do? Thanks.
Old 09-03-2003
LooneyTunez's Avatar
LooneyTunez LooneyTunez is offline
Dedicated Member
LooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of lightLooneyTunez is a glorious beacon of light
Your friend is not correct. The VTB-1 has a variable output, and can accomodate just about any input. Have you just tried turning the output level up on the VTB-1?
Are you by any chance plugging the SM58 into the "HiZ" (1/4") line input in the front rather than using the "Mic In" (XLR) in the back? If so, that would explain your lack of any type of usable level.
My Work:
Kraft Music Sales
My Hobby:
The Mix Posse
Old 09-03-2003
Senior Member
I'll try cranking the output level later on, but i believe i tried that before and it was a no go. As for the input, i'm plugging it into the XLR input on the back.
Old 09-03-2003
Dedicated Member
Check your "Input Gain" as well. You can hit the VTB-1 pretty hard without it breaking up.
My Work:
Kraft Music Sales
My Hobby:
The Mix Posse
Old 09-03-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
If the Delta has a switch for +4, -10 make sure it is set to -10. Unless anyone can confirm the VTB runs at +4. DJL or Chessrock?
Old 09-03-2003
Senior Member
yay it worked!
can't believe i didn't think of that, doh! Thanks alot TexRoadkill and Looney, helped out a bunch .
