Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 09-02-2003
rockem rockem is offline
Senior Member
rockem is on a distinguished road
Question Routing in cubase
hello all,
I need help with routing signals in cubase for :
1. Routing two channels into a single streo compressor
2. Routing Two input channels into a single audio track
thanx
Old 09-02-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
1 - create a bussing subgroup, set the output to each track to that subgroup - add any effects to the group.
2 - you'd have to combine them before they appear at the INs of your designated Cubase inputs. Without more details of your system, it's impossible to say...
Old 09-02-2003
Senior Member
Why can't I assign whatever input i want to whatever track ??
I need it to record synths mostly, since it outputs stereo signal
on my VS1824 I can do it in a press of a button
just assign let say inputs 4 and 5 to track 1 and you done
Can't I do something similar in cubase ?
thanx
Old 09-02-2003
Originally posted by rockem
Why can't I assign whatever input i want to whatever track??
You can.... if that's what you were asking, you phrased your question badly....
That's fine - as long as you have at least 2 inputs defined in Cubase, you can record a stereo track....
Well - that really isn't assigning inputs, that's more like SUMMING two inputs together - which is a mixing process.... so while your 1824 seems to have given you a shortcut, that's not a typical routing path to use without the flexibility of mixing the signals. For example, WHY do you even need to blend 2 tracks this way in the first place - send them each to a single track and you can blend them as much as you like in the s/w??! (This would be the more flexible and appropriate approach - rather than the equivalent of a misused "Y" cable that the 1824 is allowing... it is bad practice to sum outputs to a single input without use of a mixer.)
Old 09-02-2003
Kryogh Kryogh is offline
Dedicated Member
Kryogh is on a distinguished road
about stereo tracks
I almost never record something on a single stereo track. I prefer to have 2 single tracks. Way more mix/fx/whatever possibilities this way!
..hmm well, I have too admit I just realize I may be rong cuz I almost never used a stereo track! In fact, I'm pretty shure I never created one since Cubase 3.5 !
maybe I should at least try it :|
Old 09-02-2003
The only time I find it convenient is when editing - you don't have to select 2 tracks to do an edit, you can operate only on the one track...
Old 09-02-2003
Senior Member
I think you didn't understand me
Lets say I want to record piano, but I want it on a mono track
So .. how do I do it ? me jv1010 sends stereo signal and if I record only one I will lose some sounds
I want to sum it to a mono track, and you're right its just like a Y cable
Can I do it ?
thanx
Old 09-02-2003
But that's my point, a Y cable is not appropriate in this case.... you can use a Y cable to branch an output from 1 to 2 signals, but you NEVER use a Y cable to sum 2 outputs to 1 input.
To convert your stereo track to mono, you record to 2 separate tracks and pan them to center. This way you can have them either way....
Old 09-02-2003
Dedicated Member
And, do you think it will sound the same way on a mono track than on a stereo track???
Or it's just a question of panning of the keyboard? lows are out a left and highs to right?
Old 09-02-2003
Senior Member
I'm all confuse right now
My jv1010 output stereo track, and I want to record it on a single
mono track .. I don't need two tracks or a stereo one
I used to do it all the time on the VS-1824
is there a way ? a simple one ?
p.s. - another thing that annoys me, why when I click on a track
it always puts it in record mode !! is there a way to disable it ??
thanx
Old 09-02-2003
Dedicated Member
Y
Well the only way I can see, is to get the famous Y from the keyboad to one input of the soundcard :| You obviously cant assign 2 different inputs to a single channel in Cubase. (or any other pc sequencer, as far as I know)
For the Record enable thing...
File / Preferences / Editing /
uncheck "Enable Record on Selected Trak"
  #12
Old 09-02-2003
Re: Y
sorry, no.... again, you don't sum signals with a Y cable - it is BAD - don't do it!
You sum signals with a mixer.
rockem - I don't understand why you don't want to send the stereo output to 2 separate tracks in Cubase, then you can do what you want!
But in any case, most keyboards provide both stereo output and a mono output (typically at the left output - which means you connect only the left side to get a mono output...) You're making this far more of an issue than it is, and it really is not a failing of Cubase at all -- it's your understanding of interconnectivity that's the issue!
  #13
Old 09-02-2003
Dedicated Member
oops!
Blue Bear Sound is absolutely right, a mixer is a way better idea than the Y cable!
sorry
I'm a bad guy ...hit me.
BUT IM RIGHT for the preferences thing so... dont hit too hard!
  #14
Old 09-02-2003
  #15
Old 09-03-2003
Senior Member
How do I sum the two channels into one on the mixer ?
How do I turn a stereo channle into a mono one ?
thanx
ps - thanx for the fast replies so far )
  #16
Old 09-03-2003
Re: Re: Y
Originally posted by Blue Bear Sound
....most keyboards provide both stereo output and a mono output (typically at the left output - which means you connect only the left side to get a mono output...)....
Did you check this?
Anyways, a mixer, by definition - sums signals together. Throw up the faders on multiple tracks and the summed signal of those tracks appear at the mixer's outputs (or a buss, if your mixer is more sophisticated).
  #17
Old 09-03-2003
Senior Member
I will be more specified
I have a recorded stereo track .. how can I turn it into mono ?
thanx
  #18
Old 09-03-2003
Pan both channels to center position.......
  #19
Old 09-03-2003
dafduc's Avatar
dafduc dafduc is offline
B O F
dafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond repute
Pan both sides to the same location. It will still "BE" a stereo track, but it will behave exactly like like a mono track.
If you have a wave editor, you can convert the track to mono. I don't know if Cubase's internal wave editor will do this, but Sound Forge will. Acid Pro forces me to do this, 'cos it can't record in mono (???). Lame.
Daf
  #20
Old 09-03-2003
Senior Member
How can I pan both cjannels to the center if its a stereo track ??
I have only one pan ....
Are we sync at all ?
  #21
Old 09-03-2003
Dedicated Member
Oh! I see..
Well, I wasnt in sync... sorry, probabely my bad english
So, no, you cant in Cubase. well if someone know how, I'll be glad to learn something new!
Go in Wavelab, or Sound Forge, or...x... and you 'll be able to merge your stereo waves.
  #22
Old 09-03-2003
In Cubase - there's a "Convert channels" audio process you can apply to convert a stereo track to mono.......
  #23
Old 09-03-2003
Dedicated Member
I found it...
Rockem, here is the solution:
Right-click on you stereo file,
chose the "process" then "stereo flip" options.
In "stereo filp" choose "merge"
  #24
Old 09-03-2003
Dedicated Member
Ok I just tried it
And my first toughts were : what tha hell...this doesnt work!
...It works. It doesn't convert your track and channel in a mono one, but it build a mono copy on both side so, it's a "mono" track, with a stereo look :|
And it still tell you "mono/stereo mismatch" if you simply try to convert the track with the "0" "00" thing. :|
anyway, is it ok?
  #25
Old 09-03-2003
Sorry - yes... Kry's right... I meant "Stereo Flip"... "Convert Channels" is in Sound Forge!
doh!!!!!!!!
