Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-28-2003
mncheetah mncheetah is offline
Senior Member
mncheetah is on a distinguished road
Question eliminating kick through overheads
How do you prevent the overheads from picking up the kich drum?
Old 08-28-2003
Senior Member
...I mean kick drum
Old 08-28-2003
Jblount's Avatar
Jblount Jblount is offline
For the love of Drums
Location: Behind The Drum Kit Looking Out At The Meaning Of Life
Jblount is on a distinguished road
Usd a little eq on the low end on the overheads.
Old 08-28-2003
Richard Monroe Richard Monroe is offline
Been Here, Posted That
Richard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond reputeRichard Monroe has a reputation beyond repute
Overheads pick up the whole kit. Then kick, snare, and possibly other mics can be added to accentuate certain parts of the kit. If the kick is overpowering the overheads, try these solutions- 1. Put a dampening ring on the kick drum, and put a towel or small pillow in the kick drum. 2. point the overheads away from the kick drum. 3. Engage any available low cut/high pass filters on the overhead mics or pres. 4. Use EQ to cut the bass on the overhead tracks.-Richie
Old 08-29-2003
Track Rat's Avatar
Total Gear Slut
I WANT the kick in the overheads. The snare too (especially). That's where the real sound comes from. The tight mics just fill it out.
Old 08-29-2003
Senior Member
I dont know how some of you guys like kick bleed in the overheads. When I mute my overheads, the kick sounds nice and tight and solid, but when I bring them in, it makes the kick sound loose and flabby.
Old 08-29-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
If that's so, then you didn't set your mic placement properly....
Old 08-29-2003
Senior Member
I'm using Mc012s in an XY pattern about 6 1/2' high, halfway between the drummers head and the Toms. I would go higher but my celing is only about 7' high.
What is wrong with that? Is that too low?
Old 08-29-2003
Son of Mixerman's Avatar
Son of Mixerman Son of Mixerman is offline
Mix Junior
Son of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond reputeSon of Mixerman has a reputation beyond repute
OH's might be too low?... yeah, LF is probably getting trapped as a standing wave on your ceiling.
Try carving out the kick with Eq and putting a gate on them if you don't want the kick in the oh's. The snare FR is too close to the cymbal FR and so Id look to tune that relationship better. The trick with OH placement is frontal placement balancing with the streo field. A way to cheat is put the OH mic on rolling mic stand, get the L/R placement right buy just hitting the hihat and the ride. gaff tape a pole to the stands an roll them fwds and bkwds while the drummer is playing until you balance the 3-D field. I often use tape measures and a calculator when doing basic mic setup (321 rule) gaff tape and poles for setting and locking positions once Im set.
Nothing more frustrating than clumsy folks bumping a mic stand that results in phase problems.
SoMm
Old 09-02-2003
skyy38 skyy38 is offline
Banned
skyy38 is on a distinguished road
Why don't you try using a trigger in the bass drum with a killer bass drum sample?Go direct and mix the mic'd and sample sounds until you come up with something suitable.
Old 09-02-2003
Track Rat's Avatar
Total Gear Slut
Have you checked the phase of the kick mic against the overheads? If it sounds good till you turn them up, sounds like it could be out of phase.
  #12
Old 09-02-2003
MarkoPolo's Avatar
MarkoPolo MarkoPolo is offline
Kill or Be Killed
MarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really nice
The way that I Keep the kick from bleeding is by putting a Blanket
over the front of the kick covering it and the mic, I had learned this from some Pro Studios I used to record in and it helps a lot.
Marko
  #13
Old 09-04-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
That would be my guess.
The close drum mics are usually there to supplement the OH sound. I don't see why would you want no kick in the OH's. That's 80% of the sound.
  #14
Old 09-05-2003
MarkoPolo's Avatar
Kill or Be Killed
I agree overheads do add most of the sound but I tend to like my kick to have a lot of punch and snap and if your not recording in a huge room the tones most of the time in smaller rooms dont add what I like to here in my kick sound, in smaller rooms you will get more tighter reflections that can take away from the punch of the kick.
Marko
