Old 08-28-2003
lopie lopie is offline
Senior Member
lopie is on a distinguished road
recording comprression sonar 2
does sonar rellay apply compression when your recording a new track or does it apply it after track is recorded
Old 08-28-2003
dachay2tnr's Avatar
dachay2tnr dachay2tnr is offline
One Hit Wonder
dachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond reputedachay2tnr has a reputation beyond repute
AFAIK Sonar does not apply anything while recording. If you are using input monitoring, you can monitor the effect, but the recording will still be dry.
It should be easy enough to test. Record a track using a very heavy effect. Then remove the effect from the Patch Box and see if you can still hear it.
Old 08-28-2003
moskus's Avatar
moskus moskus is offline
The Creator of Æ, Ø and Å
moskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond reputemoskus has a reputation beyond repute
What Dachay said.
You need hardware if you want realtime compression.
Two wrongs don't make a right, but two Wrights once made an airplane...
