problem exporting to mp3
i'm have a problem exporting to mp3, it keeps telling me that i don't have the right sample rate and bit depth for my project how do i change this so i can export.
Two wrongs don't make a right, but two Wrights once made an airplane... |
yes i have the full version. i'm running sonar XL 2.1. i'm guessing there's just a setting issue. i go into options > audio and change the sample rate and bit depth but still can't export.
![]() -- BluesMeister |
Porter |
Well I was having untold problems last night exporting an audio file to MP3.
After several attempts it dawned on me that the MP3 encoder with CakeWalk HomeStudio doesn't like spaces in the file name! So BPOM CWR.MP3 wouldn't work, even though I didn't get any error messages! It happily went through the whole process, even asking me for bit depth and sampling rates... When I looked for the MP3, it simply wasn't where it should have been. When I tried BPOM_CWR.MP3, bingo! We were in business. ![]() However, I certainly did get the opportunity to change the bit depth and sample rates with the encoder program, had I wanted to. CWR = Click With Rhythm -- BluesMeister |
I just did a test and tried to export a 44.1/24 bit mp3 from Sonar. Sonar gave me the following message:
"MP3 encoding can only be performed on projects that are set to a sample rate of 32, 44.1 or 48 KHz, with a bit depth of 8 or 16." If your project does not meet this criteria, it would seem you need to change the project settings. This is done under Options -> Audio. |
