I want to sample some pieces of a song in sonar and I don't know if that is possible or not. Wound you guys recommend a different sampling software? Which one?
Any suggestions would help. Thanks
B-FACE |
You can record any audio that you can get in there at any length you want, but there is no provision for using that bit of audio as a building block to be used in any samplers (as in sample-playback synths). You could certainly build up a song using such snippets and editing them one by one to appropriate lengths and pitches but if you're talking about creating a sound set to play via a keyboard, SONAR is not an appropriate tool
What AlChuck said, but when you have a sampler, use Sonar to play it. And it sort of comes with a sampler if you buy the XL version. The DR-008.
Two wrongs don't make a right, but two Wrights once made an airplane... |
You can use Cyclone to chop up and play the samples.
Can you trigger the samples with a midi keyboard in Cyclone, or invest in a external sampler?
B-FACE |
You can trigger samples with Cyclone , but if you want more control over your samples you should get a "real" sampler such as VSampler 3 or DR-008 bundled with the XL version (actually DR-008 is a dedicated drum-sample player, but can be used to play all kinds of samples).
An alternative is SoundFonts. If you have a SB Live/Audigy you just need Vienna to make some soundfonts and use them with your SB-card. ![]() Go here to read James Argos beautiful Soundfont tricks!!!! ![]()
