Go Back   Home Recording > User Forums by Brand > Cubase User Forum
Reply    Audiofanzine Steinberg Steinberg News Steinberg Medias Steinberg Tests Steinberg Articles Steinberg User Reviews Steinberg Classifieds Ads
Old 08-21-2003
bean 123 bean 123 is offline
Junior Member
bean 123 is infamous around these partsbean 123 is infamous around these parts
VST and MIDI latency...
I use a SB extigy right now, and use both Cubase SX and Reason 2.5. I have adjusted Reason to the point the latency is tolerable (around 69ms) but cannot seem to adjust SX at all. I've searched this forum, the manual endlessly, and experimented for hours, and I'm still unable to get the latency down....I am using the monitor feature ( which also has latency w/ audio) and the only conclusion I can come to is that I must get a new soundcard... the words " zero latency monitoring" sounds VERY appealing in the product descriptions....Is this my only choice??
Old 08-22-2003
Bass Master "K"'s Avatar
Bass Master "K" Bass Master "K" is offline
Force of Nature
Bass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud ofBass Master "K" has much to be proud of
Have you adjusted the buffering for your SB to lower the latency?
In general though, SB's are not great for recording, but some people do make it work.
Old 08-22-2003
dafduc's Avatar
dafduc dafduc is offline
B O F
dafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond repute
Zero-latency monitoring is a process where incoming audio is shunted directly to the monitor to avoid latency - doesn't even pass through the cpu. It does NOT apply to monitoring VSTi's.
If Extigy has an ASIO driver, use it. You should get your best latency there. If not, you'll want to find a box that does do ASIO. M-Audios are good if you're on a PC.
Your other option (I do this, 'cos my PC's old and a bit slow) is to monitor your outboard synth directly, record the midi, then point it to a VSTi (with full latency offset). This can make for better timing than you get in a barely-tolerable latency situation - you don't want to do the full offset, because you were adjusting your playing to compensate, but there's not usually any one value that will get you good clean timing. This wouldn't be an issue, of course, with latency under 6 or 7 ms...
Daf
