Go Back   Home Recording > Equipment Forums > Keyboards and Sound Modules
Reply    Audiofanzine Electronic-instrument Electronic-instrument News Electronic-instrument Medias Electronic-instrument Tests Electronic-instrument Articles Electronic-instrument User Reviews Electronic-instrument Classifieds Ads
Old 08-20-2003
copperandstars copperandstars is offline
Junior Member
copperandstars is on a distinguished road
Keyboard controller setup...please help!
Hello,
I am having problems with the Fatar cmk-49 controller I just ordered. How does the computer recognize this device? It came with a cord that goes from the midi out on the keyboard to the serial port on my computer. I use Cubase SX and can not figure out how to set the cmk-49 as the midi controller. Any help is very much appreciated.
Thanks,
Ryan
Old 08-20-2003
z00dave7 z00dave7 is offline
Newbie
z00dave7 is on a distinguished road
Hi Ryan - long-time keyboard player here, and I have used Cubase for a while, though I'm no expert.
First off.....what exactly are you trying to control with the controller? - VST instruments? If so, hooking up your controller makes sense. You could control one or more of these with your controller, treating individual VST instruments with your controller, assigning different sounds/patches to various splits on the controller, etc.
I hook my controller (midi OUT) up to the computer via the midi IN on my soundcard, and send the midi out on the soundcard to the midi IN on my JV 1080, or my XP 50.
Be sure to make sure that the midi channels match up.
Hope this helps)
Dave
Old 08-20-2003
Junior Member
Thanks for the response Dave,
The reason I purchased the controller is actually to use it with vst instruments. I think I know how to set up the softwear the correct way, I just can't figure out how to get the controller recognized by the computer. No softwear or drivers or anything came with the controller...but I am pretty sure that is how most (or all?) controllers are. Like I said before it has a cable that goes from the midi out into the serial port. Any ideas?
Ryan
Old 08-21-2003
Krakit's Avatar
Krakit Krakit is offline
Rzzzzz!
Krakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond reputeKrakit has a reputation beyond repute
All keyboard controllers are recognized the same way by your computer depending on which port they go into.
There are only two MIDI possible input ports on a computer that I am aware of.
The USB port or the MIDI port on a sound card.
I'm guessing that you have the latter and are trying to put it into your serial port. That won't work.
Is your soundcard embedded in your mother board? If you have a soundcard in your PC it should have a port that looks like this:
Carl
“The modern conservative is engaged in one of man's oldest exercises in moral philosophy;
that is, the search for a superior moral justification for selfishness.”
-John Kenneth Galbraith
Old 08-21-2003
dafduc's Avatar
dafduc dafduc is offline
B O F
dafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond reputedafduc has a reputation beyond repute
Don't some soundcards make you use another connection? Joystick or something?
I've NEVER used a setup like that - my soundcard only handled sound, not midi. Got a separate usb midi i/o (midiman2x2).
Youy might want to take the plunge and get a midi connection, copper. But you may also find yourself really frustrated by latency issues with your VSTi's if you're not using a soundcard that does ASIO...
Daf
Old 08-21-2003
Krakit's Avatar
Rzzzzz!
Yes, the MIDI port on a sound card is the joystick port too.
I should have mentioned that.
It's cheaper to just get a soundcard with a joystick/midi port on it than any other PC/MIDI interface.
You can have two soundcards in your computer and use the cheapie for MIDI input only (if your legacy card is Prosumer or better).
Carl
Old 08-21-2003
rvf263 rvf263 is offline
Junior Member
rvf263 is on a distinguished road
Maybe this might help.
http://musicmall.com/cmp/article6.htm
http://musicmall.com/cmp/article7.htm
Old 08-21-2003
Junior Member
Thanks for the help.
I read trough all that, tried to reconfigure everything, and still no luck. I think I might just get a usb midi interface.
This is a real newbie question I am sure, but what purpose does the midi in on the keyboard have? Mine only has an output.
Thanks.
Old 08-21-2003
Krakit's Avatar
Rzzzzz!
If your keyboard had onboard sounds, you would be able to control these sounds via yet another keyboard, or a sequencer or a computer or whatever else you have with a MIDI output on it.
If your keyboard is just a controller, it has no inherent sounds and therefore there is not point in having a MIDI input.
Carl
Old 08-22-2003
Junior Member
copperandstars,
What kind of soundcard are you using?
Old 08-22-2003
Junior Member
Usually I am using my M-Audio Delta card as my soundcard, but it does not have any midi support. The soundcard that came stock with my computer is a C-Media AC97 I believe. In my device manager it says something about a MPU-401 compatable midi device. I'm not sure what this means.
I just purchased an M-Audio usb midi connecter...I decided it would make it a lot easier in the long run even If I could make my soundcard cooperate.
Thanks.
Ryan
