Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-13-2003
terrible_buddhi terrible_buddhi is offline
Dedicated Member
terrible_buddhi is on a distinguished road
carving the turkey
I just recording the drums...they have not been eq'd yet, and I want to add the bass in...how should I eq this track to make room for it?
http://www.foxytravel.com/YE/mixdowns/far_away%20sb.mp3
Old 08-13-2003
Blue Bear Sound's Avatar
Blue Bear Sound Blue Bear Sound is offline
Don't feed the bear......
Blue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond reputeBlue Bear Sound has a reputation beyond repute
Re: carving the turkey
Well... why not? You'll get much better results if you record it the way you want it to sound, instead of throwing up mics and worrying about how to "fix" the sound later....
In this clip, the drums are extremely muffled and wooly-sounding, and lack any definition or impact.
The snare in particular sounds like someone hitting a cardboard box with a stick.
The cymbals are far too forward and are imbalanced relative to the rest of the kit... as well, there's evidence of comb filtering due to poor mic placement (caused by phase problem with mics in too-close proximity to each other).... this causes the washy kind of sound....
I'm afraid before you worry about adding a bass in there - you'll need to retrack the drums to make them acceptable! And get the bass player to play along with you when you set up the mics - that way you can check what the two instruments will sound like together on the monitors. First step though, is getting the drums recorded properly!
Old 08-13-2003
MarkoPolo's Avatar
MarkoPolo MarkoPolo is offline
Kill or Be Killed
MarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really nice
it also sounds like you eather did'nt use a kick mic or bad mic
placement. it sounds hollow with no punch ??
Marko
Old 08-13-2003
TexRoadkill's Avatar
TexRoadkill TexRoadkill is offline
Audio Bum
TexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond reputeTexRoadkill has a reputation beyond repute
And that belt makes your ass look fat
Old 08-13-2003
Dedicated Member
yes...this belt DOES make me look fat
ok...lets start with the kick...I am not thrilled with the sound either...We took off the outer head...put a pillow in it, and the mic is on the outside of the drum pointed at about the beater.
Old 08-13-2003
FattMusiek's Avatar
FattMusiek FattMusiek is offline
hates cables.
FattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond repute
First, like Blue Bear said, get the sound closest to what you want first THEN EQ. Second, I would make room for the drums, not the bass.
Listen to my songs at:
http://www.nowhereradio.com/artists/...y.php?aid=2076
The purpose of a cable is to get stuck under everything in its path.
Old 08-13-2003
FattMusiek's Avatar
hates cables.
Oh, you never replied to my previous post where I gave you a link to a recent drum track I did.
http://members.cox.net/fattmusiek/drums.mp3
Hopefully Blue Bear will come back and give me some advice.
Old 08-13-2003
Not too bad FattMusiek.... a little wooly and dark-sounding and maybe a little too much "room" for my taste, but it may be entirely appropriate for your context!
Old 08-14-2003
Audio Bum
Buddhi - How are you miking the kit? What mics?
Fatt- Not bad. The cymbals and toms are pretty decent but the kick is a little weak and the snare has too much ping. You might try loosening the snare springs for a little more snap. Kicks are tough. My advice for a good kick these days is get a Sennheiser E602.
Old 08-14-2003
Teacher's Avatar
Teacher Teacher is offline
do unto others......
Teacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond reputeTeacher has a reputation beyond repute
or you can do it the EASY and cheaper way which would be to sample replace...
"...if the opposite of pro is a con lets go beyond this, the opposite of CONgress must be PROgress..." Cage
Old 08-14-2003
Dedicated Member
can't bring myself to do it...I want to get the sound right.
When you guys are tracking do you ever use low pass or high pass?
  #12
Old 08-14-2003
Dedicated Member
ok, here are some pics of how I have the set miced...any obvious flaws?
http://www.foxytravel.com/YE/photo/MVC-180L.JPG
http://www.foxytravel.com/YE/photo/MVC-181L.JPG
http://www.foxytravel.com/YE/photo/MVC-182L.JPG
http://www.foxytravel.com/YE/photo/MVC-183L.JPG
  #13
Old 08-14-2003
Audio Bum
Generally a spaced pair of OH's can be a phase nightmare. You might try searching the forum for RECORDERMAN DRUM and you can read a cool technique. I do a variation of it where I put one OH directly above the snare just out of the way of the drummer. I tape a string to the center of the snare and to the kick where the beater hits. Pull the string so it makes a triangle with the first OH mic. Then move the string to the right and when it is tight that is where the second OH will go. It will only be about a foot apart but you get great mono compatability and a good picture of the whole kit.
Put the kick mic on a boom and place it closer to the inside skin. Point it at the beater. That will give you a much tighter and clickier attack. Remember to INVERT the phase on the kick mic. This is crucial to a good sound.
Try angling the snare mic flatter and pointed more at the center of the snare. You can also try micing the bottom or side of the snare for more crack. If you mic the bottom be sure to invert the phase on that mic also.
For a big snare sound you can add some reverb to just the snare mic and leave the OH's dry. A large room reverb with a fast predelay and short decay can work well. There are also some cool compression tricks that are vital to a big drum sound. You can compress the hell out of the OH's for a very roomy Bonham type sound. You can also run the kick and snare through a compressor set w/fast attack and release so it really pumps and mix it back in with the dry tracks. That will give you a big and punchy drum sound.
Good luck.
  #14
Old 08-14-2003
slabrock slabrock is offline
Newbie
slabrock is on a distinguished road
Sennheiser e602 is not that expensive, is it? Less than $200 in Europe, and i must say i love mine, which i bought the week they came out. It's way cleaner and more articulate than a D112, not as soft and unfocused as B52, it feels like it has all the good qualities of Sennheiser's excellent all-around-mic MD421 plus extra in the bass end.
In my mic cabin it comes second only to my 50's edition AKG D12, when a bd has to be mic'd, which may imply that it's quite a classic - a recommended buy, for sure. Good bass drum mics don't come much cheaper.
(Ok, i got the much appreciated chance to boast 'bout my mics. Thanks for you patience.)
Sample replacing is for SFX. You don't learn anything using a drumagog or such device. Recording drums is the most fun part of it all, why lose all those chances to experiment?
Ahh, building a cradle for another bass drum for resonances; driving the toms out of a PA set at 180dB and mic'ing the room...
That's fun!
Slabrock
  #15
Old 08-14-2003
Dedicated Member
I am not sure how to reverse the phase on the kick, I have a Mackie 1604 VLZ. Also, how high above the snare do you put the OH?
So you think that is why the kick sounds like crap? Its out of phase?
  #16
Old 08-14-2003
Newbie
Reversing phase: if your console doesn't have a "phase invert" -switch, you can do a phase inversion adapter out of a short XLR cable. You just cross the hot and cold leads, and leave ground as it was.
'The Famous John Bonham method' of placing the OH is to put two drumsticks vertical over the center of snare. Two drumstick lengths is about right.
Kick being in or out of phase is not the reason here, athough you can gain some, by testing it. Take the pillow out, tune the drum properly, dampen it only lightly and place the mic inside BD, about halfway in (or slightly closer to the beater side), and on a proper boom stand, not lying on or touching anything.
IMHO you can do better with a single OH than with a spaced pair (sometimes even better than with an X/Y-pair), unless you know just what you're doing. Rock drums are practically mono these days, anyway.
And while you're at it, try placing the snare mic a little further from the head, and slightly towards the centre of the drum.
I was happy to see, that you didn't have too many damping tapes on heads. That's always good to see, good!
Happy recordings,
Slabrock
  #17
Old 08-14-2003
Dedicated Member
hoping someone sees this quickly...I did the recorderman method...its working much better...BUT the mics are not equidistent from the kick, but they are from the snare...should I move the kick drum itself?
Also, I have the first mic aimed at the center of the snare (the mic upside down) I have the second mic pointed there as well (about a 45 degree angle) is that right for a B1?
  #18
Old 08-14-2003
Audio Bum
That sounds about right. I would try to keep the mic equidistant from the kick also. Use a string or cable and it will tell you exactly where to put the mic.
  #19
Old 08-14-2003
Dedicated Member
ya, I did the cable thing...got close, but I would have to move the kick drum itself to get it equidistant to the kick & snare...with the double bass drum pedal he uses its near impossible...but it is close, and I think when I post the sound tomorrow...it sounds worlds better!
  #20
Old 08-15-2003
Dedicated Member
here we go...no eq, pannned the left and right @ 10 & -10, no compression, no reverb.
I used the recorderman technique...it does seem to work much better...tell me what you think.
  #21
Old 08-15-2003
zekthedeadcow zekthedeadcow is offline
Dedicated Member
zekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond reputezekthedeadcow has a reputation beyond repute
I haven't listened to this yet but I don't like micing on that side of the kick drum...expecially if it's not likely for it to be properly tuned.
Personally I would take the pillow out... put the head back on and ...being a really frick'n small kit (godda love 2pieces ) ... put a bass mic like a D112 or a Beta52 or whatever on the end of a boom mic stand and place it right above the kick mallets...with double bass, right inbetween the two mallets. that way the snare is behind the mic and it will get a hell of a lot crisper attack.
With that setup the kick mic is over two feet from the source of the sound....and the pillow isn't going to allow the shell to resonate evenly...so you get a weak bass harmonic thing going among other things...pillows are evil...just remember that
It's hard to tell but it sorta looks like you have a wrinkle in the kick beater head...Remo's are fine but I converted to Aquarian heads ...and it's fairly apparent that the pedal mallets arn't hitting in the center of the drum from the apparent placement of the pad. http://www.foxytravel.com/YE/photo/MVC-183L.JPG
I personally don't like those muffle rings either...but I also don't like gating... yeah snares are supposed to be crisp but it's also supposed to have a slightly extended decay too... but it depends a lot on style
...and the room is square...and it looks like theres actually too much deadening material...
Bear in mind I'm saying this as an experienced drummer and not as an experienced engineer
  #22
Old 08-15-2003
Dedicated Member
all the mics have been moved from that previous pic...including the kick mic.
The room is all concrete, except for some bass trap style wood I put on the ceiling. I also put up some other stuff to keep it from being so rectangular.
The way I was micing before was a total nightmare, I think this will work a lot better.
  #23
Old 08-15-2003
Audio Bum
I'll try to remember to give it a listen when I get home.
  #24
Old 08-15-2003
Audio Bum
That's sounding better. The kick is much more present. That snare is still a bit dull sounding. The drummer needs to really hit it instead of those wimpy taps. A new head might help. With a little compression to give it a more full sound I think you're on the way.
  #25
Old 08-16-2003
Dedicated Member
ya, he does hit it hard...that is why he needs a new head...dented this one already I also have that mic padded so I have some decent headroom.
Any other tips on mixing it?
