Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-08-2003
terrible_buddhi terrible_buddhi is offline
Dedicated Member
terrible_buddhi is on a distinguished road
I am here...need to be here
Here is what my kick and snare sound like now (this is dry, no verb, no pan, no eq)
http://www.foxytravel.com/YE/mixdowns/far_away%20sb.mp3
I want to be here:
http://www.foxytravel.com/YE/mixdowns/jew_drum.mp3
Please help...mic placement, eq, compression..whatever, just let me know...thanks!
Old 08-08-2003
Bulls Hit Bulls Hit is offline
Been Here, Posted That
Bulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond reputeBulls Hit has a reputation beyond repute
Your snare needs to be tuned up a little, and the snares themselves tightened a tad. This will sharpen you snare and it will cut through more.
To my relatively untrained ears the second drum sound seems to have a fair amount of limiter applied.
You can trick up your sound with some top end eq to lift the hats and cymbals, and a bit down low for more snare and bass punch.
Some reverb to add space, and compression to smooth things out. Then finish it off with quite a hard limiter to get that sound you want
Old 08-08-2003
Middleman's Avatar
Middleman Middleman is offline
Professional Amateur
Middleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond reputeMiddleman has a reputation beyond repute
What is the source for the first track? Is it live or waves or sound module.
If its live, closer micing of the snare and focus on the 1000 to 2000 range. Roll off below350. Very rough guess here.
The kick needs roll off above 100 and below 50, push 3-4 db with narrow Q around 3000 to get that slappy sound.
If its waves, get another set of wave files. You can't EQ it that much and still have it sound right.
If its a sound module either get a different set of drums closer to the sound you are looking for or tweak the basic tones using the above ranges to get close.
Compress the crap out of the hi hat i.e long release. Turn up the volume on the snare. Put the 2500-3500 range on the kick through a lightly applied short reverb. Put the snare on a good room verb. Mabe a slight gate on the snare.
Compress the overall drums about 1-2 db, 6:1 ,moderate attack moderate release. Better yet limit it slightly as reccomended by Bulls Hit.
That's about as close as I can guess.
Old 08-08-2003
MarkoPolo's Avatar
MarkoPolo MarkoPolo is offline
Kill or Be Killed
MarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really niceMarkoPolo is just really nice
Also how many mics did you use for your kick and snare?
Because overheads play a big part in how the snare sounds also.
Marko
Old 08-08-2003
FattMusiek's Avatar
FattMusiek FattMusiek is offline
hates cables.
FattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond reputeFattMusiek has a reputation beyond repute
I think it's your mic placement. I don't think the second drum track is good, either.
Listen to my songs at:
http://www.nowhereradio.com/artists/...y.php?aid=2076
The purpose of a cable is to get stuck under everything in its path.
Old 08-08-2003
FattMusiek's Avatar
hates cables.
Er, I forgot to add that that 2nd drum clip sounds a lot like older Get Up Kids.
Old 08-11-2003
Dedicated Member
the second drum track is the beginning to a jimmy eat world song...I am a huge fan of their sound
The track is live and I am not even sure what you mean by waves file
Right now the only 2 mics I have on it are the kick and snare. Trying to get those right first...that kick is driving me nuts! Still not getting the sound I want. I think I got a little closer with the res head off...but still don't quite have the mic placements right...I am btw using a b1 on it.
Old 08-11-2003
Dedicated Member
oh if any one wants to take a stab at the kick (eq or whatever) to see if that track is salvageable...I would be most appreciative!
Old 08-12-2003
FattMusiek's Avatar
hates cables.
You're working with only 2 mics? I use 4 (I only have 4 i/o's), the overheads make all the difference.
Old 08-12-2003
FattMusiek's Avatar
hates cables.
Alright, I listened to your track again. First off, how are the mics placed? Typically, I mic the snare (SM57) about an inch over and into the head. For the bass drum (Shure Beta 52), I point the mic at the beater, 5 or so inches away. To me, it sounds like you don't have a hole in your bass drum head. If you don't, cut a hole for micing purposes. Overhead mics are crucial in basic drum micing, they capture the overall sound of the kit.
http://members.cox.net/fattmusiek/drums.mp3
This is what I'm working with.
Old 08-12-2003
Well I tried a remix.
It sounds........different from what it did. Not sure it's what your after though.
Here's the first 20-odd seconds
http://homepages.paradise.net.nz/roc...far%20away.mp3
  #12
Old 08-12-2003
FattMusiek's Avatar
hates cables.
Man, you overcompressed that kick...sounds like a kick drum is hitting the capsule of a mic and not a kick drum head. I don't think there was much to do to salvage the track, it's all about mic placement.
  #13
Old 08-12-2003
Dedicated Member
bulls...Thank you very much for giving that a whurl...seems like I am overpowering the mic, and the sound is not savable. I am going to pick up a kick drum mic tonight and give that a try...I will post again after that...THANKS!
