Go Back   Home Recording > General Discussions > Mixing / Mastering
Old 08-07-2003
Munchkin Munchkin is offline
Newbie
Munchkin is on a distinguished road
Disc Makers Format Questions
I've mixed a bunch of songs for a band and they have chosen Disc Makers to do the matering.
Disc Makers say they accept CD-R format (among others) for thier mastering process.
Is CD-R a format that I can produce on my PC?
I may be wrong, but should this disc be a DATA CD?
Is there anything else I should be aware of before I hand this band a finished disc and say it is the correct format for Disc Makers?
I thank you...
Old 08-07-2003
christiaan's Avatar
christiaan christiaan is offline
1K Silver Member
christiaan has a spectacular aura aboutchristiaan has a spectacular aura about
Ok, I guess Disc Makers is some kind of company.
You know... Instead of assuming things I think the best thing to do is to just ask Disc Makers. I'm sure they'll be more than happy to help you out.
Old 08-07-2003
DonF's Avatar
DonF DonF is offline
Call Me "Grandpa"
DonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond reputeDonF has a reputation beyond repute
http://www.discmakers.com/rom/contact.php
Old 08-07-2003
Newbie
Okay,
I will.
Old 08-11-2003
charger's Avatar
charger charger is offline
1K Silver Member
charger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond reputecharger has a reputation beyond repute
What they're going to want is an audio CD. It's recorded on a CD-R, yes, but unless you are contracting DiscMakers to do some sort of post-production work on your music ("mastering", which is different from "glass master"), all they do is check the disc for errors, then make a glass copy of it, and burn a bunch of copies.
Old 08-12-2003
Scinx Scinx is offline
Mechanical Monkey
Scinx is on a distinguished road
I believe the intent is to have them do mastering - not just making a glass master.
Old 08-12-2003
charger's Avatar
1K Silver Member
In that case, I strongly urge you to reconsider. DiscMakers does not do a good job with mastering; I've heard several projects that went through there, and the best I could say about them was that the volume levels were similar. A real mastering engineer is well worth the investment.
Old 08-13-2003
Mechanical Monkey
Per Jack Endino, check out Eddy Schreyer at Oasis Mastering and/or John Golden at John Golden Mastering if you want a real good job...
