Go Back   Home Recording > Equipment Forums > Drums and Percussion
Reply    Audiofanzine Drum Drum News Drum Medias Drum Tests Drum Articles Drum User Reviews Drum Classifieds Ads
Old 08-06-2003
mm2k5 mm2k5 is offline
Junior Member
mm2k5 is on a distinguished road
Live kick sound
when i run my kick into our board all i get is a thud, and i am wanting more of a punch. The actually kick sounds great but i cant get it to go though the board with the same sound. Should I tighten the heads so there wont me as much of a thud? The board is a 3 band eq anything i should fine tune it to? Thanks
Old 08-07-2003
Tim Brown's Avatar
Tim Brown Tim Brown is offline
Why 2K?
Tim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond reputeTim Brown has a reputation beyond repute
1. What kind of heads are on it?
2. What kind of muffling is in it?
3. what kind of kick mic?
4. how is the mic placed in relation to the drum? (i.e., outside the batter head? Inside?)
5.How are you tuning it?
6. what kind of mallet are you using?
Tim
Old 08-07-2003
Junior Member
1. What kind of heads are on it?---the beater side i have evan g2 and the other i think is like a g2, but has the hole in it
2. What kind of muffling is in it?---I have some towels, should i invest in a small feather pillow?
3. what kind of kick mic?--- my mics are peavey, i got the package with all 5 mics, they are great to everything else.
4. how is the mic placed in relation to the drum? (i.e., outside the batter head? Inside?)--- I use my drum mic case to prop the mic on the other head...it is right in the center about 3 inches away
5.How are you tuning it?---right now both heads are pretty loose
6. what kind of mallet are you using?---Gilbralter pedal with plastic beater
Old 08-07-2003
theletterq theletterq is offline
Dedicated Member
theletterq is on a distinguished road
Higher tuning + muffling = punch
Old 08-07-2003
Junior Member
what kind of muffling would you recommend? feather pillows?
Old 08-07-2003
Tim Brown's Avatar
Why 2K?
Buy a "Evans EQ gate" pillow.
You can either crank it up in pitch, or you can detune it completely...I mean, leave it so loose that the metal almost jingles and the head still has some slack and wrinkles in it.
Tim
Old 08-10-2003
Jblount's Avatar
Jblount Jblount is offline
For the love of Drums
Location: Behind The Drum Kit Looking Out At The Meaning Of Life
Jblount is on a distinguished road
Yeah evan's makes a good pillow/pad that you can muffle the front head with.
Old 08-12-2003
Tim Brown's Avatar
Why 2K?
I wouldn't put it on the front head, that would be a complete waste of money. You're supposed to put it on the back head, because when you hit the head, the little "gate pad" moves away from the head, then moves right back into place cutting off the ring of the back head.... and yes- it will give you killer punch live.
Tim
Old 08-12-2003
Junior Member
so which side would you put the mic on with that evans thing?
Old 08-12-2003
Tim Brown's Avatar
Why 2K?
The pillow mounts against the back/batter side, and the front side is left to resonate freely.
Them you'd put the mic inside the kick drum throught the front / resonant side head.
The Drum will be big, but punch sounding.
Tim
