microkorg and fruityloops?
Hi I was wondering if you could transfer a sliced drum beat from fruityloops and save it as a program on a microKORG.
I am only using line in, not midi. How would I go about that? |
No you could not.
A program would be referred to as a patch on the microkorg. And a patch is simply the saved settings of all the parameters of the synth at the time the sound is saved. The microkorg is a virtual analog synth that creates the sounds it makes by manipulation of waveforms. It doesn't use samples.... But you could however, run a line out of your soundcard into the microkorg for use as the "waveform" to manipulate. Which is pretty much the equivalent of vocoding with a soundsource other than a mic. |
